Old 06-08-2017, 10:52 PM
seattleworm seattleworm is offline
Default RV7 on the Beach
Landed on and took off from WA beach. RV can do it!
Shawn Li
RV-7-First Flight 5/27/2014
RV-10, Tailcone completed, waiting for wing kit
Old 06-09-2017, 07:23 AM
stancaruthers stancaruthers is offline
I suggest you put the drain plug in tight and fill with fresh water....shake for 5 mins then drain, repeat process until sodium residue is less than .002 ppm
Old 06-09-2017, 07:30 AM
Arie's Avatar
Arie Arie is offline
Which drain plug are you talking about?
Old 06-09-2017, 07:32 AM
Mel's Avatar
Mel Mel is offline
That would be the "bilge" drain plug!
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 175hp O-320, 3-Blade Catto (since 2003)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-09-2017, 07:40 AM
Arie's Avatar
Ahh. I see. Thanx Mel, but I thought a RV will only float if the approach speed was to high.
Old 06-09-2017, 07:54 AM
Default Port.
And always check your port running light. You don't want to get hit by a stray Sea Gull on that side when the sun is low on the horizon.
Yours. R.E.A. III #80888
Old 06-09-2017, 10:15 AM
bret's Avatar
bret bret is offline
Nice! So.......how did you get back in without tracking all that wet sand into the plane?
2018 gladly supported
Old 06-09-2017, 11:03 AM
OrenAir OrenAir is offline
Beautiful plane. The action shot in photo 1 came out awesome.
Old 06-12-2017, 04:03 PM
daddyman's Avatar
daddyman daddyman is offline
Shawn,
I'm going to do this on the right coast.
Looking for the "Zen" spot.
Daddyman
Old 06-28-2017, 04:36 PM
Bret,
Haven't checked this post for a while. The only drawback of landing on the beach is the cleaning part. Not so much about the salty sand, it's an easy hose over. But getting the sand out of the cockpit is a major task. Make sure I will bring another pair of shoes next time.
Shawn Li
