I used the dry Ice and wouldn?t do it again; I would just put some type of lube on them next time. I did use my rivet gun with a scrape of aluminum between the gun and the head of the bolt and slowly tap them in! Don?t forget the washers on the heads of the bolt on the bottom. With the gear leg weldments you can?t turn the nut on the bottom bolts that?s why you need the washer on the head
Ray
What did you do to ensure the holes were lined up? I can't get any of my final bolts in. I do have a couple bullet bolts in for alignment. But the final bolts won't go past the first part of the spar. They are hanging up on something. Did you wiggle the wing? Other ideas? thanks
