Old 11-17-2016, 09:40 PM
longranger's Avatar
longranger longranger is offline
One of the nutplates in the F-766A flap motor channel contains the 12,000th rivet of the project...
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on order
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 03-28-2017, 06:00 PM
longranger's Avatar
Letting a little long overdue sun shine on the project. It's 45 degrees here in southeast Michigan, but with the overcast melted away and the wind near calm, it was time to open the hangar door and enjoy a cool one (the criteria is that the day is warmer than the beer )
Not a lot of progress lately on the -7. My excuse (and it IS just an excuse), is that I've been spending a lot mental energy on the fact that my Cessna 170B is almost ready to return home. Some may remember that in the summer of 2014 '98C was savagely attcked by a renegade hand-propped Cherokee.
A slightly generous insurance settlement got the lions share of the repairs done, and kicking in some coin of my own got her a few upgrades, cosmetic repairs, and new paint and interior. 32 months later she's within a week or two of coming home. All she needs are a few touchups, a static system check, and a weight and balanceYIPPE!
Construction Log
Old 12-29-2017, 02:18 PM
longranger's Avatar
Default I MUST have done something wrong...
...because things rarely work out for me as well as they seem to have for the initial fitting of the wings on my RV-7.
After plugging the wings into the fuselage, putting two 7/16 hardware store pins in each side, then clamping the rear spar fittings where they fell, we hung two plumb bobs off each leading edge and stretched a string along the floor. The sweep is within 1/8 inch all the way across. Measuring for square from the rivet in the forward outboard corner of he outboard main skin back to a point on the centerline of the aft deck just forward of F-711, the two sides are within 1/16 inch (out of 187-5/8). Checking incidence, both wings measure 0.1 To 0.2 degrees nose high at the root and tip, and about 0.3 degrees nose high midway between.
I cant help but think Ive done something wrong. Ive marked the rear spar bolt holes in the center of a 1/4 x 1/8 rectangle that will give adequate edge distance on all the parts, and will walk away until tomorrow when Ill clamp a drill bushing in place and remeasure everything.
Construction Log
Old 12-30-2017, 12:45 PM
BruceP BruceP is offline
Hi Miles,
I dont think youve done anything wrong, I think your numbers are excellent. A tenth of a degree will be unnoticeable and could be random variation. I bet even the temperature you measured it at could create tiny changes in the metal. At least both wings are identical in measurements and Im sure your plane will fly excellently. Id say drill the holes and build on!
Bruce
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 9/17
Old 12-30-2017, 08:43 PM
longranger's Avatar
Good to hear from you Bruce!
Since that post I test fit the flaps, and the inboard end of the lower skins lacked about 1/16 touching the fuselage. I had about that much spar stub extending below the forks on both sides, so I bumped the trailing edges up that far, remeasured about a half dozen times, and today finally committed drill to metal. I have both sides up to 1/4, and will see if I can borrow a 19/64 drill bit and 0.311 reamer from one of several local builders who have done this before.
If I had known it was going to be this easy I would have done it some time ago.
Good help, and they didn't even visit the kegerator. (that might have something to do with it being 12*F outside...)
Inboard edge of upper flap skins need to be trimmed slightly.
My Rube Goldberg Wing Incidence Measuring Tool.
Left side. Right side looks pretty much the same.
Construction Log
Old 02-17-2018, 12:00 AM
longranger's Avatar
Default First RV-Grin From Inside the Future N904KM
I needed to remove the control column to adjust the stick angles, and couldn't reach it from outside the airplane, so I took the opportunity to document the first time sitting in the airplane.
Construction Log
Last edited by longranger : 02-19-2018 at 12:09 PM. Reason: Changed “inside” to “outside” (duh...)
Old 02-17-2018, 08:55 AM
jcarne's Avatar
jcarne jcarne is online now
Very cool Miles keep up the good work!
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 02-17-2018, 11:29 AM
longranger's Avatar
Thank you Jereme! This should have happened 2 years ago. There is NO excuse for this airplane not being done, being retired and having a heated hangar less than 30 seconds from the living the room couch...
Construction Log
Old 02-18-2018, 08:51 AM
jcarne's Avatar
Haha better late than never, too many people in that category...
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Old 02-18-2018, 04:57 PM
kentlik's Avatar
kentlik kentlik is offline
Heated hanger! Lucky! Man, that looks like great work!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
