I am about to close the access panel and install the fuel sender unit, but I am not sure if the fuel sender and float are supposed to rotate. I have bent and cut the metal rod that attaches the float to the sender unit correctly and attached it. I noticed will test fitting that the float and metal rod will swing around easily. Is it supposed to do that? Is there not a chance of it hanging up in a barrel roll or unusual attitude?
