2100 hour Borescope
petehowell
It's that time again! Just did the 2100 hr oil change and took a peek at the valves. Oil filter and suction screen had some crumbly carbon bits in them, but no metal I could see. The magnet on the filter had a thin film of micro iron stuff that wiped right off.
Compressions were 77/72/78/77. #2 has shown a bit low before, but typically comes back on the next test.
here are the Exhaust Valves I added some "pop" in Google Photos.....
Ls8zLJtn0wN73xTYRc1ENLubuH5YF64wFt70HMlGZ_4kKM9Hf5s6i9Xj7UiYq_dQjTQvYR1VnzayVfOGy4MBT5DTafj29zculb02y2TpXgiQfRaQtAqr7r8EJ-PLlzCT9YKC0ByvOyW8P_lBuB26qQ_SD7l3hKpDlQo6WvcmmjZYBanf0IBjdFBDZlYTyCslntDYgSrAzOwgGfpBfZHh8JEo3qNQelUrM7xWikA0H-lwM-f4-05xHAuDbHQoEmY6ARBStpgqwhqWm7LXEDLySzPOHEuOZkQTHwVFeOWGpq9eS05hZhHE_Of3da8Yl8wtpgDh2bnGBBVyHhqPsjLAUG3C1Vf4myVZGYj9z0jMmgZWkrHMC4juI1ujgADUVDafeh5OBYr_B32gzWj4UYX7kTemDfJFIKgoR0Lc3b-83uD9-hNl41hc4YErH3w3IzceGXZ9F3qpVEVAq8yKivEbUp69dtuPUQ_NYuWlLIhSyt8SrxQ5dGM0aKlMZxk_5vFnrMLTshK43ZuP9kqLh8cPfn2J-TnzsvmMEUKwPOeTK1nVeIow0-AqwO4MKbZA6iZfxr8BEAB2O9IyhoH3-3zsZTylzTAOWfKoQ0ftKkjFpOC_TDSpdSahKphm-VxIWAI7N98FFsaPANHn38EP3gnkvwCQQvwhARjzjK16b6hMZfgILTyDUA__qsZlBzxc1u80jg2Fqkq2zZzWmPjvriw=w640-h480-no
hLeEoZBaIPEUxE9fXoLkZz7jFt5v24_yuILktM3NRRcCM_A0Ob6kPsmdO1nwihzuy-3Jr5GOfPhcEM3Zr9Gsgh3iOa172nUIb8iXag2DtRxXfWaF_dvK8VEItsHvpmue96V7ypQb-mH6pdGmiSOHtWSflhp_e5_OJhE9wK1EKBZcz2nu48O7GPGJVqf-bDbsp5TaKkMQ573xKs2whI1l1x3hARjiEFaIEr6bzfa0IfNbVlUyr497YsxEqLdzA8qDfULE1dNENmb1VP_hNW-VmKUdllFgQqC8X0xeW1zICBNtizdZ8E99ptS_8iUbCv00M0NhXsMqlotsQeYMpJh88nlAUdqS-T4EIIa3dgeGbhvTPxRA0CszA21-zd9HgTAll5AJAeGcR69Q216fhYHyTjMT3_y5YcyC6hocXcqBPvFDsZ6wMaGgd8GC7xkxGmFNDztulWOwRnT5Dd6_wy9r043r0Xt6yYO6_nL9Gr00NAPIi7Dy0v5hBY5as4JDDVVHzFNiXFA77QxZToHZJ-1BeNA3tLuFWAiE5sFKHT6vKgQFKBs1rNjO3l_LBCD5ZA-EMz_Wh8K_zboVVI_ru7cfTYZznVWvfeOaKLo4SyJVfFZpNx2LL8FBKW4HWYyp2NdF9KOrdeOase_moJ84mhZXJmdmATDe0Xdh4JlhggVpsrmm44qtGHKUgd3j8xgAYgJSux9bwbGZlKfAgohyJ2w=w640-h480-no
XOfrnZzkK1FbqCDu7L5V02jZTBEqzBwnOHzNOd9PRlQeeyvbRfC3f3yAyEvy54VauZpj0t-Sbt-Od6AXSgkFzZ8q9H0lN57tWKhZh5YDDA_pMdQVlAEnIsdoJyk0bAxLTV4DMKlCs4msZkysvodSUkqt4xHS4uuZj-XDH6pqT9puyj-_PMkhjgvtjP-q8jzIf-VMyTj9FohQAJ6K92MIVceo5rV4tXGJFZO1p-DFvUD0kORG7ZOGd2FBwL8y34jie1h83S0_FJNAvJ-aYxFTvnPxkqTNzU82o_j42M-bxwixifYSiiQeixRf1f42Aixes0ViRU-XapIhbt5MFW8lOUmepExsUY2-0-Gaj63G52Q41_jbuAnbfBsWbg2I9PO5o4KmIGpqEZjXJYX34UN4hx2xBDRgAlahbzYNahnrEyD4uujBJWVPR2gVev9rH9m2zsSFgEdHPuHfu9_vUCUwIm0_YMBjDgJNxMfDySRJjDW4tm6SOqjSBf9hYXvVkDKfEgcD866n8oWP3J7w-5ujoUBUkKq3bVteg9XgGWvq4MsDox4i0DFLydAvD8ZpltqMe2hS1c0rjGWi6wG9Lg607rQN6q6JTjd3oHzvKaSgFDbTf4dO3LwF6Kp4KqdU3eIh38tI8w592RpzJU1B1AgmTOTXgfQQyWO-ICou9Wh8e9jXfyWWrgq3XmIleoh-1Yo1Qd0VdaYEGn4GlYdkaxE=w640-h480-no
cwhMjTtYRWGfoiJHnPZMYSX1XNqH76403yTsIX6dvvqg1NSZUyIlSavv0IPYb-88jsqbQhGoUYsqdikEhFWEVLkvW_v5w92dIy4RKc5stXX3NAz0rlR4Mb5zk2JbLD3wC4juLWyCDgfBJmDJ62DSEM3McteqObE28hyqjNNlnojd4VyQzhRCfbKS4NnIrt0gDFmDnfkXXJ4g1oO0Cl91BxQXdUPqR_rxvFKyGsAL4v4NCoPnm1XXIIfqoAwjvFDiXpsYTsmFATz3XXQJSwAjdymlwHshe84ihGjxKooMKVHvNxd58LysMq8CL9mL1YDOjphv8Wi4ttGLnlEO3YqqbIkQ0u8XC3q8qfafLr8PJNUanTKaXAzZcyPFHGoRmttk8JnuliV-yUk9YaJEj43bg1RqAm0gA0EteepvU3oNaDVWdNo5c9gvq_QQC4M50cRdWD1rZP6SioZnWHUnNFaOMnyBWuVHGThbIyAY5kIwOpVriwLplhGEckV4nDyHwv-_pO60LQziX66V7TCkRUdc4OP5l2iWePCu9NYHzSzR4sX4LXBMVeHz1f5vLL--LrGGLIE4Gofb3dwV8xGdPOlg2eWFRj-sW3x1NmetIDBNB6SVW5dcxkb8QXyAPRCzmOtozfo8XC0DefDs57H_WWI3DAwPnqZ28DEKDsnrVJBqWcROZzgtWu06W6I5tccG_mZq1POyMoI7HSok_QP7HI8=w640-h480-no
One intake valve - because I thought the color/pattern was cool.
QRFPRCLtnAPEGJYnxQdXXgez_rrNqID3oIJFQdGrGUnqFeHx-wggxRLGWXADhcftt1dhPTt6jNwmkh_C_-UO-XbGvLvD2I3eQUTyYqqkpvYsJ3ZxHqv32nuxzBCeqdOAWptX4pjJ9Kbpeo2nLGAIE8Y7IzBQHXajfs1qg56rfDC3lnI-IcX3I3yZhUOw_fZVCwsMMFQ9kNCcHK7-JL16t_DKigl4akfnMhuvIVEWYkTs18gZS_sgRjzCrdxbJNJjHCZUGBz-QWX4WHv7OxbYDmOwxYhz1kvah-U7jmGYE-ryS0jDrb9Mqj5-jwPw34GMSJQT8NUo9RP7VmUk3hhJoEqpI1Lo7i__A3EaNHnifCpsN_P-XYCu14JikSRozm8rHtasPccvsTNMQxvGyeww0bhq-H6p9D7SbEKdb8xo45MMdSfWvvp9TZ0zbSaq9xjj4Ue2r_gRmU8_EGrIPFgk7xjUtkfIxXC-Zlomn_xkaQ_3iKYFb_MW2wfqx86XS5itQuYtEnXO2E-RilREwNMu36WDiKrFgv1J-O2x2JCOuaUW8uFHL9Yo0MyqTnADRBDBoCEB-9mh2FowV7iJ2tuO291fsPsfDZVD6Nfi3y-llPr3s3mhaa6DQuKcgSf_SHaiJ4sqff3e1-G18jBNh1LqBPvbf1ZFvDA38463DVLLY96hlbIiFsyVXpq_X5rBYdEqpXBiridohYQMpJofEKw=w640-h480-no
Excellent quality images. Could you tell us what type of borescope you used, and what type of fuel?
Tom.
Hi Tom,
It is little usb camera on a wire - there are several that have been listed here previously(I don't have the link handy). I run mostly 92 mogas - some 100LL on the road.
Tom.
