snoop9erdog
All, does anyone have a recommendation for toggle switches that are fairly compact on the back side (electrical connection side)? Not sure if it's possible, but my goal is to use Van's standard instrument panel with 10" G3X's and still fit my line of toggles under the PFD panel. Looking At about a 1-1/2" available on the front of the panel which will be close but should work, however on the backside it may be an issue.
Trying real hard to avoid adding a switch panel to the bottom of the instrument panel and keep that leg room.
I really like the standard panel dims.
Anybody contemplating this?
