Old 08-25-2012, 08:48 PM
TXFlyGuy TXFlyGuy is offline
Default Mobil One, Anyone?
With an auto conversion powered airplane, is there any reason not to use a good synthetic oil? Are synthetics compatible with 100 LL? If not, why not?
Old 08-25-2012, 08:54 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Don't
My understanding, not personal knowledge, was that Mobil-1 aviation oil was taken off the market because it did not properly "scavenge the lead" in 100LL. It was used in the Voyager world flight, but later discontinued.
For car gas you have a different set of issues, of course.
H. Evan's RV-7A N17HH 230 hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
my website
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
Old 08-25-2012, 08:57 PM
What about Aeroshell's synthetic blend 15-50 oil?
Old 08-25-2012, 09:44 PM
dlomheim dlomheim is offline
Default Mobil One and "alternative" engines
From all I have read over the years the synthetics didn't work reall well in aircraft engines due to the greater amount of blow by associated with the looser clearance of rings on an aircooled engine, etc. Many of my rotary buddies (Mazda 13/20B engines) run Mobile one and 100LL or 87 octane car fuel without any issues and that is what I will use in my 13B when I get it flying...
Doug Lomheim
RV-9A; 13B / FWF (on hold for now)
RV-3 O-290 under restoration (former GPU...sorta of an "alernative engine"
Old 08-26-2012, 08:34 AM
chaskuss chaskuss is offline
Myron,
This would be a much better choice, if 100 LL will be used. It has the correct "ash-less dispersant" additive package.
Charlie
Old 08-26-2012, 08:45 AM
Originally Posted by chaskuss View Post
Myron,
Charlie
Thank you, Charlie!
Old 08-26-2012, 09:13 AM
rocketbob's Avatar
rocketbob rocketbob is offline
You could run Mobil 1 if you take care of the ring and piston clearances. When was the last time you've seen a gasoline car engine oil turn black?
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 08-25-2012, 09:58 PM
RV6_flyer's Avatar
Anyone that has been around aviation a while would not use a 100% synthetic oil in an engine that uses 100LL if you gave them the oil free. Too many engines were destroyed by Mobil 1 aviation oil when it was on the market. The synthetic oil does not handle the lead well and the sludge that formed destroyed the engines.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-26-2012, 08:04 AM
gipsowh gipsowh is offline
Default Do NOT use synthetics
Bud Warren told me to never never use synthetics with 100LL. The lead will turn it to a gray sludge and destroy your engine. Use SAE 30W or 5w-30 and keep it clean. Period.
Bill Gipson
N730WL
LS1 Geareddrives powered RV-10
Conroe, Texas
Old 08-26-2012, 08:25 AM
So the primary fuel in use will be 93 octane mogas. And the engine most likely will be a Chevy. Considering that on occasion we might be limited to 100LL, what oil would be best suited for this application. And what about Aeroshell 15-50 synthetic blend?
