Old 10-15-2017, 02:25 PM
myrv7 myrv7 is offline
Default Need some advice--I made an extra hole!
I'm building the tailwheel model and currently working on Section 10 that deals with attaching the Vertical Stabilizer to the Aft Fuselage assembly. In the plans excerpt below, you are instructed to match-drill three 1/4" holes and final-drill two #12 holes in the locations indicated.
Well, let's just say, I didn't exactly follow the directions! I still can't believe I did this!? I mistakenly drilled a 1/4" hole in the location identified as "#30 Drill Bit". It is UNBELIEVABLY obvious to me now that this hole should NOT have been drilled. Here is the result:
I emailed Van's support and was instructed to insert two more rivets between the Systems Hole and the side edges of the Hinge Bracket and add a bolt/washer/nut to the errant 1/4" hole I mistakenly drilled. The rivets would work out fine; however, due to the bend in the Hinge Bracket, there is not enough room to fit a nut (or bolt). Ironically, on the RV-14, if I had not accidentally drilled the 1/4" hole in the first place, the previous #30 hole in this location would NOT have received any hardware and be left open. So.....
Couple of questions:
1. Since there is not any hardware ultimately used in this hole location (al beit it should be a #30 not a 1/4" hole), can I just leave as is?
2. Should I rebuild the Vertical Stabilizer Spar (as it now also has a 1/4" hole in it) and replace the Hinge Bracket due to the "extra" hole I drilled?
Lastly, regardless of what I do to the Vertical Stabilizer Spar, there are also now two holes in the F-01412A & B Bulkheads. As shown below, one hole is the Systems hole (should be there) and the other is the 1/4" hole that should not be there.
3. Can I leave these Bulkheads as they are with the two holes?
4. Should I replace the two Bulkheads due to the errant hole?
Any advice would be greatly appreciated! Thanks in advance.
VJ
https://myrv14.blogspot.com
RV-14 S/N #140316
Empennage--In Progress
Old 10-15-2017, 02:53 PM
YellowJacket RV9 YellowJacket RV9 is offline
Iíll bet you could could get a bolt head there by either slightly grinding off an edge, using a modified washer underneath it, or both. I may or may not have an extra bolt or two in my plane. Still seems to fly okay...
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 10-15-2017, 03:05 PM
cczarnik cczarnik is offline
(Deleted) realized you were waaay past the emp.....
Chuck
7a emp complete, wings underway
VAF Dues paid - 2017
Old 10-15-2017, 03:11 PM
N427EF N427EF is offline
Default Take Van's advice
NO
NO
Refer to Vans advice!
However, I can see your problem trying to use a bolt in that location for the reasons you have mentioned.
Perhaps Van would let you use the System hole for a bolt rather than trying to
make a bolt head fit in the radius of that hinge bracket. This would require a 5/16" bolt or larger to fit the system hole.
Don't get consumed by this minor issue, it can easily be solved without replacing major components.
In any case, check again with Vans.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 10-15-2017, 03:13 PM
Send these concerns to Van's. They need an engineering decision. Only Van's knows what the loads and stresses are in that area.
(old retired aerospace stress guy)
Old 10-15-2017, 04:54 PM
Mel's Avatar
Mel Mel is offline
How about installing a 1/4" nut plate to the bracket side and inserting a bolt from the forward side?
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-15-2017, 05:29 PM
sblack sblack is offline
Is there sufficient clearance from the bolt head to the flange of the fitting? It's just the radius that is the problem? If so, bevel a washer to conform to the fillet and install the bolt. You could also put an extra rivet on either side of the big hole respecting the edge distance.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
Old 10-15-2017, 05:52 PM
Mudfly Mudfly is offline
Hard to tell from the picture how much room you've got for the bolt head. Check out McMaster-Carr for ideas on different bolt head types. A couple stood out that have small diameter heads when I had a quick look. Round Neck or Tugger bolts, and socket head screws. Maybe also consider a carriage bolt with part of the head ground down flat. Would need to find one with correct grip length (non -threaded) and without the square part underneath the head.
Looks like you're very particular and your work shows it, so know this bugs the heck out of you. However, form the sidelines here, I think I would try and follow Vans advice if possible. When your done, you'll have one of the strongest tail sections out there
Shawn Edwards
RV-14A (140174)
Empennage purchased (pre-owned) August 2015
www.myrv14build.blogspot.com
Old 10-16-2017, 06:32 AM
maniago's Avatar
maniago maniago is offline
Personally I would have put two rivets either side of the errant hole, verifying good hole spacing and leave the open hole alone. The bolt wont add anything that the rivets arent accomplishing, except weight. But since Vans told you to put a bolt in then grind off one side of the head and install. And build on.
FWIW, we have a three of these ground back bolt heads at a bend area in the M2. The bend takes up any strain the missing bolt head area might give up. In our case, the strain is most definitely in the direction of the bolt shank so head surface area is a consideration and its the only thing holding the bracket on. You already have several rivets accomplishing the goal.
Just my .02.
Mani
Bushby Mustang II (Folding Wings) "Wiring stage. Yea!" IO-360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,Mini-x,EIS,480,327,240,SL30,Echo; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
Old 10-16-2017, 07:32 AM
Default Thanks
Thank you everyone for your advice and insight. Iíll follow up with Vanís for additional options. Thanks again.
VJ
RV-14 S/N #140316
