Old 10-11-2017, 05:55 AM
JDA_BTR JDA_BTR is offline
Default GSA28 Trim Output
See this thread: http://www.vansairforce.com/communit...d.php?t=141478
It points out that the wiring from the GSA28 to the trim motor should be shielded. The G3X docs show it clearly. In our stock Vans wiring it is not run this way. Has anyone had problems with the unshielded wiring in an RV14?
N1463 seems a good number....
Old 10-11-2017, 07:20 AM
jump4way jump4way is offline
I donít have an answer but am interested in opinions here as well. I too installed the Ray Allen 26g 5 conductor wire that is unshielded and am trying to decide if I want to run new wire.
Old 10-11-2017, 07:43 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Here is a link to a similar thread where Steve addressed this question. The short answer is the shielded wire is there to help limit potential interference with other systems on the aircraft. It may work without shielded wire, but if you run into noise issues caused by the trim motor running, unshielded wire is going to be one of the items we want to rule out.
Regards,
Brian
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 10-11-2017, 08:24 AM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Default No noise in my plane
I am using the wiring harness as supplied by Van's (no shielding on the pitch trim wires). I have not experienced any noise that I can detected. In the Garmin diagrams, i'm not sure if there is a single wire that they don't spec out as shielded
Jared Solomon
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 10-11-2017, 10:03 AM
KeithB KeithB is offline
Same results - 130+ hours on the plane, standard Vans harness and no issues with trim noise or interference.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, Phase I compl Apr 3, 2017, >220 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
