bret
Does anyone know if there is a difference in the distance at the valve cover width between the two engines as far as the Vans baffle kit rear wall goes? or is this a trim to fit piece? I will be going with some type of plenum for the James cowl, heard bad things about the fit of the James plenum and looking for different avenues. buy a plenum cover? fab up something different? seen an all aluminum plenum on the 409 RV 8 race plane last Reno race.......
