Originally Posted by Lucky Aviation
I am wondering if anyone might share pictures of their RV-8 flop tube installation. The plans do not show a lot.
Give me a day or two. My anti hang up brackets do not cover the access door opening. This improves access compared the the way the plans show. I also installed flush fuel drains from a King Air and installed NAS 1473-A08 nut plates to eliminate the fuel leakage problem, that Vans designed in.
I was going to refer you to another thread. However, I've discovered that the photos on that thread are no longer there.
Check out the thread linked below for photos of my flush fuel drains and the "trap door"you need to install on the 2nd fuel tank rib.
http://www.vansairforce.com/communit...ight=flop+tube
Charlie
