Old 12-27-2011, 10:10 AM
mlwynn mlwynn is offline
Default Problem Solved
Hi all,
Thought I would tell you all how this worked out for me. I swapped a couple of PM with Chris Welsh. I ended up getting some CR 3214-4-4 rivets from Chris. With a couple of twists of a deburring tool, they fit flush and pretty. Paul was right, with a little polishing from a stone to smooth off the top, they are pretty hard to tell from the bucked rivets.
ACS does not carry these rivets nor mention their existence. Chris is practically a neighbor (and the producer of a really nice rear throttle control) and was kind enough to supply me with the correct size. Otherwise, I might have ended up trying to use a regular 1/8 Cherry, which would have required some serious reaming. It is good to see regular suppliers appear here to help future builders if/when they encounter the issue.
So, once again, the VAF comes to my rescue.
Regards,
Michael Wynn
RV8 Baggage Door
San Ramon, CA
Old 12-28-2011, 11:36 AM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
Originally Posted by Capflyer View Post
Sorry this is slightly off topic. I have heard this ocassionally but cannot find it documented where there is a manditory gear bolt torque inspection. Nothing listed on the mother ship site unless I missed it. Can someone please point me in the right direction? I'm trying to decide if the tower mod is something I want to do and now is the time on the current project.
Mike - Build Manual 8-44 - after 10 and 50 hours then anually.
Regards
Bob Ellis
www.rv-8.co.uk
Wiring nearly complete
Old 04-05-2018, 12:22 PM
SgtZim SgtZim is offline
Default oops
Just to bring this back up on the radar. I started to read this post and jumped on the first thing I read - ordered the "wrong" rivets which was very easy to do since Aircraft Spruce has lots of them in stock and you can buy them in quantities of one. I should have read the majority / multiple folks said get the 3214 rivets and the company "Genuine Aircraft Hardware" even chimed in as a source for the harder to find rivets (at a very fair price)
So, bottom line: go to the above source and order 3214-4-04 Cherrymax rivets and save yourself a lot of trouble and pain trying to get those an rivets set.
Kudos to you folks who can bend that way and set normal rivets!
Now I gotta go try to knock out some 3212s.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 04-15-2018, 02:25 PM
DTARM1 DTARM1 is offline
Well said.
