Old 12-16-2009, 10:14 AM
Brantel's Avatar
Brantel Brantel is online now
Originally Posted by shuttle View Post
p.s. Your labelling looks good, Brian. Is that another example of Decal Pro labelling?
Nope, just a plain old Brother labeler from WalMart. They look OK but if I had it to do over, I would try something else. With the burgandy color of the panel, the edges of the clear tape show pretty bad.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-16-2009, 10:36 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Brantel View Post
You can also put your control cables in the panel but if you ever want to pull the panel, you have to disconnect them from the engine......
To get around that potential headache, I fabbed a small extention to contain the cable assemblies. Attached with 3 screws/nutplates at the flange it can be quicky dropped clear and away from the main (oversize) instrument panel.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 12-16-2009, 10:38 AM
JonJay's Avatar
JonJay JonJay is offline
Default me too
I did the same thing. It was easy to fabricate and works very well.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-16-2009, 10:49 AM
Brantel's Avatar
Yep that is an option similar to the stock setup but I did not want the additional part sticking down as I am thick and crawling under there is hard enough already with the extra panel length.
Old 04-03-2018, 10:48 AM
wirejock's Avatar
wirejock wirejock is offline
Default Installing panel
Reviving an old thread.
I have the Oversize Panel. It's been cut and match drilled to the existing panel. I made an end shape template to get the correct dimension for the outboard bottom ends. Perfect but...
It won't go in! It won't clear the F704C. It looks like about 1/2" would have to be removed. That defeats the whole purpose.
How did others get the Oversize Panel in?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
