Old 04-16-2018, 06:59 PM
bayoubengal bayoubengal is offline
Default Compressed Air Hose Size
Hooking up my compressor. Any pros/cons for 1/4 or 3/8 line?
Hutch
David W. Hutchinson
NAAA Certified Aircraft Appraiser (Nationwide)
Perry, GA.
RV-10/N433DH (Res)
www.TwoEaglesAviation.com
Old 04-16-2018, 07:07 PM
scard's Avatar
scard scard is online now
For building an RV? Unless you are going further than 500' with 1/4" hose, NO. It doesn't matter.
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Old 04-16-2018, 07:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Building or painting
For building (riveting, drilling, etc) I use a 1/4 line long enough to cover my work area.
For painting (HVLP) I use a 3/8" line.
Maybe it doesn't matter. I've sprayed with the 1/4" with no problems.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-16-2018, 08:22 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Use this handy little chart -
A 5 cfm die grinder at 100 ft has a pressure difference of about 10 psi for a 100 ft of 1/4 vs 3/8. probably would have no effect.
However, if you have a big honking compressor and have tools that use a lot of CFM, then the bigger hose size would be better.
I sometimes need almost 100 ft lines to get air out to the ramp in front of my hangar.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-16-2018, 08:59 PM
SMO's Avatar
SMO SMO is offline
My die grinder and my orbital sander run noticeably stronger with the 3/8 line. I use 1/4" line for my 1/4" drill, rivet squeezer, cleco remover, and pull riveter.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
Old 04-16-2018, 09:19 PM
coffeeguy coffeeguy is online now
Looks like I overbuilt. Story of my life. Put in 3/4" Rapidair line to my basement and garage and have 3/8" hoses. I have added the 1/4" flexible Cleaveland hose for ease of use the last few feet. And when I cook I always have leftovers...
Jeff Dingbaum
RV-14A empennage, wings
Cherokee 180
2018 dues paid
Old 04-16-2018, 10:16 PM
Hoses have differing flexibilities. I prefer the more flexible ones - to me, with my limited hose lengths (typically 25' or 50') that's more important than size. However, I haven't painted with these yet.
Old 04-16-2018, 11:43 PM
gasman gasman is offline
When plumbing for air, consider each 90 degree elbow to have the same loss as 20 feet of same size pipe...... you can't overbuild.
VAF #897
2019 =VAF= Dues PAID
