Old 04-16-2018, 10:59 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Turning on my crankcase heater
I need a method to turn on (and off) my crankcase heater. I was told in an EAA meeting that Verizon has such a device. I just got off the phone with Verizon and they say they do not. Keep in mind there is no wi-fi what-so-ever near the hangar, so this device must communicate with a cell phone tower and I assume it will have it's own phone number. Been hunting and hunting on the internet and cannot find one.
So I remembered Van's airforce and I figured you guys would have the answer.
By the way, leaving it on 24/7 is not going to happen, as has been suggested by my technical friends.
Thanks guys..
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
Old 04-16-2018, 11:03 AM
jabarr jabarr is offline
Www.switchboxcontrol.com
Old 04-16-2018, 11:09 AM
RV6_flyer's Avatar
Default SwitchBox Control
I used one of these for 4-years.
I gave it to a friend when I moved as I now have 18-steps to my hangar and hangar is on the same WiFi network as my house. Yes I have a WiFi switch that I can now turn it on and off with.
The SwitchBox Control worked great and I had great communication with the owner. Using a T-Mobile SIM card it only cost $3/month to operate. The unit I had was an older 2G unit that is NOT upgradeable.
IF you are technically inclined like I am, you can build your own with parts you buy on the Internet but I did not have an issue paying a little more for a Turn Key system complete with App to operate it.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 04-16-2018, 11:33 AM
Default Thanks, I just ordered it...
I just ordered it... I am not clear as to who or how I send the monthly fees, but I am sure it will be explained when I get the package...
I just hope some one else doesn't tell me about some other device that costs half as much. This was $300...
RV-10 N1861G
Old 04-16-2018, 12:37 PM
rdrcrmatt rdrcrmatt is offline
Does anyone know if the switchbox web app has an API?
Matt
2018 Dues Paid.
Old 04-16-2018, 01:10 PM
flightlogic's Avatar
flightlogic flightlogic is offline
I use Switchbox. What is an API?
"Kindness is never a bad plan."
Work bio: Avionics tech support; ATP rated in planes.Helicopter rated, balloon instructor, seaplanes and for grins, Phantom Drone pilot. Instructor for air medical and law enforcement tactical radio systems. Fly my RV9A to work every week. Janitor when and as needed.
Old 04-16-2018, 01:32 PM
Raymo's Avatar
Raymo Raymo is offline
Originally Posted by flightlogic View Post
What is an API?
Application Programming Interface.
It allows developers to write code that works with an application without having the vendor's source code. The vendor would provide documentation on the API functionality.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 04-16-2018, 06:10 PM
Rupester Rupester is offline
Default Another $0.02 worth ....
Switchbox works great and support from Phillip is absolutely top notch. Anytime I've emailed a question to him, I get an answer within a matter of hours.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-17-2018, 06:32 AM
rvsxer rvsxer is offline
I second the motion...
Mike Hilger
RV-6 N207AM w/G3X, 1,400 hours +
South St. Paul, MN (KSGS)
Senior Tech - Panel Design, SteinAir, Inc.
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 04-17-2018, 10:40 AM
rleffler's Avatar
rleffler rleffler is offline
Since we're experimenters.....
This is same box the Switchbox sells, but you have to set it up and configure it yourself. But you save quite a bit of $$$$.
http://www.wafer-shopping.com/4g-ver...l#.WtYjOjMUn5J
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
