Old 04-16-2018, 10:28 AM
SR2500 SR2500 is offline
Default RS232 Feed
I've searched but can't seem to find an answer. I have an RS232 feed coming from my KLX-135A to my Tru Trak ADI. However, I didn't allow for a feed to my Tru Trak Digitrak. Can I simply split the feed from the KLX-135A and use it for the ADI and Digitrak? Simple Solder Sleeve splice would be easy.
Jerry Folkerts
Jerry Folkerts
Pietenpol, built and sold
Cygnet SF-2A, built and sold
Cygnet SF-2A, refurbished and sold
Murphy Super Rebel, built and flying
The Pedal RV, designed and built
Vans, next build
Old 04-16-2018, 10:39 AM
TShort TShort is offline
I'm far from an electronics expert, so I can't answer to the ins and outs of splitting it.
However, when I first bought the -10 there was an issue with the RS-232 feed to my Digiflight II, and after some research and discussion I split the feed just like you mentioned.
It worked just fine.
That's my "n" of 1, FWIW.
Thomas Short
KUMP - Indianapolis, IN
RV-10 N316JS bought / flying
RV-8 wings / fuse in progress ... still
N329TS (had it, lost it, looking for new number)
Old 04-16-2018, 12:09 PM
Noah's Avatar
Noah Noah is offline
Yes you can. I feed 3 RS-232 GPS inputs from one GPS using a terminal strip with no problems. At higher baud rates, you need to be careful with noise / interference / shielding / twisting wire, but not with lower baud rates as I understand it.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous menÖ for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 04-16-2018, 12:15 PM
BobTurner BobTurner is online now
Generally speaking, yes, you can split one out into several inís. Because each input does consume some power, and the out can only supply so much, there is a limit. But most RS232 outs can drive two inputs; some can drive three; etc. Of course all of these inputs will be at the same format and baud rate.
