Old 04-15-2018, 11:51 PM
fbrewer fbrewer is offline
Default Full Flaps or No Flaps in heavy winds
Members,
There are lot's of suggested techniques in heavy winds (above 15 knots) for the tail dragging RVer.
Some suggest NO flaps, some suggest Full flaps.
What do you use and what is your rationale?
Likewise: wheelie or 3pt, and your rationale?
Old 04-16-2018, 01:02 AM
Tram Tram is offline
We talking crosswind or down the pipe?
If they're down the pipe, I have no issues will full flaps.
If they're crossing, I'll go without the flaps or half flaps.
I prefer wheel landings in higher winds..
Old 04-16-2018, 07:14 AM
Simon Hitchen Simon Hitchen is offline
Default Same same
Max crosswind, half or no flaps and wheel landings.
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 04-16-2018, 07:27 AM
blueflyer's Avatar
blueflyer blueflyer is offline
Default All or none
I was taught the "All or None" method for high crosswinds. Meaning use all the flaps or no flaps. 80% of the time, I choose all the flaps. I wheel land 90% of the time anyway, so I wheel land in high crosswinds too.
Old 04-16-2018, 12:19 PM
6 Gun 6 Gun is offline
Default Flaps
100% flaps every time.
Bob
Old 04-16-2018, 02:48 PM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
100% flaps all the time, even in sever cross winds...
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1620 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
Old 04-16-2018, 04:04 PM
Mike S Mike S is online now
When I did my transition with Mike Seager, he made me do a no flap landing just to show me it could be done.
I asked if there were times where it was preferred, and he replied something like "if the flaps are in working condition, why would you ever choose not to use them?"
Old 04-16-2018, 04:23 PM
bret's Avatar
bret bret is offline
From what little I know, the less flap in the spam can gave us a higher approach speed which in turn gave us more rudder authority in a cross wind, I don't think that applies with our large rudder....
2018 gladly supported
Old 04-16-2018, 11:12 PM
Bret, thanks for your reason.
Anyone else have reasons why they might choose NO Flap and 3pt vs Wheelie?
Or Wheelie vs 3pt.
This applies to winds over 15 knots, variable and gusting to 25.
Old 04-17-2018, 12:05 AM
Ironflight's Avatar
VAF Moderator / Line Boy
When I have really strong crosswinds, I generally leave the flaps up becasue I am goign to keep some speed up to maintain better control, and once I am on teh ground, I want as little lift as I can get - to keep the airplane from trying to lift back off. The flaps will lower stall speed, and I actually want a HIGHER stall speed to facilitate killing the wing’s lift.
I also use a wheel landing with significant crosswinds becasue I want more speed for better directional control until I have planted the airplane. Then with no flaps, it is less likely to balloon back off the ground if I take a sudden gust, because of the higher stall speed. Less lift, less likelihood of lifting back off.
BTW - I don’t really consider it “windy” until the wind is sustained over 20 - for 15 knots within 45 degrees of the runway, I would probably still be using flaps.
Usual disclaimers apply - this works for me, YMMV, and I don’t give flight instruction over th internet!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
