Old 04-12-2018, 06:15 AM
huzilulu huzilulu is offline
Default Newbie here... Planning on building a RV10
Hi Everyone
My name is Huzi, and I am in the planning stages of my RV10 build... I must admit I do not know a ton about these kits/planes, and will be studying up as much as I can through the forums...
I hope you guys can help me with some initial questions:
1) What are the recommended tools (in addition to the list on Vans website) that will help with the RV10 build?
2) What are the recommended mods builders have to the factory kit?
My goal is to have a 4 seater plane that I can fly cross country/neighboring countries with relative ease...
Thank you in advance!
Old 04-12-2018, 06:46 AM
Electrogunner Electrogunner is offline
Default Search
The search function here will give you enough info to last at least a couple years of reading. Have fun with the build is the most advice I can give though.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 04-12-2018, 06:50 AM
Auburntsts's Avatar
You'll get lots of opinions on those questions. However they've been asked before so I suggest reading these 2 threads first:
Tools - http://www.vansairforce.com/communit...d.php?t=150434
Mods - http://www.vansairforce.com/communit...d.php?t=149298
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-12-2018, 07:23 AM
rleffler's Avatar
rleffler rleffler is offline
Start reading all the builder's logs. Tim's at myrv10.com was the gold standard for quite awhile, but some of the information is a little dated due to updates in the last few years. He does talk about some of the basic issues with the plans and the appropriate course of action.
Find some local builders. I know that there are several RV-10s in your area.
Understand that all of us have an opinion and usually think that ours is the only way to do things. Usually it's just a bit of ego and attempting to justify our own purchase decisions. It's your aircraft. Build it the way you want it.
Last but not least, try to make Oshkosh. There is a strong RV-10 builder community there, with even a RV-10 dinner on the Sunday before. You'll learn more talking with the other builders face to face.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-12-2018, 10:13 AM
Thanks for the suggestions...
I live in dubai so I doubt there are any RV builders here (any model)... my plan is to start the build here and then move it to Houston when I move back to TX in summer 2019...
I'd love to visit Sun n Fun or Oshkosk, but it'll have to be next year as this year is just not possible ...
Cheers!!
Old 04-12-2018, 10:38 AM
ppilotmike's Avatar
Bob's advice is good advice. Before you pull the trigger, you should do some more research and talk to some RV-10 builders and flyers. There are several 4-seat designs to choose from, besides Vans. You may still decide that the 10 best fits your needs, but then again you may not. I would recommend starting your build in Texas, instead of starting in Dubai and then moving it. It will cost you less and you will have a lot more support when you start, which is very much needed, as you will be a beginner and have lots to learn, initially.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 04-12-2018, 06:34 PM
jamcgee1978 jamcgee1978 is offline
Hi Huzi
Welcome to VAF , im a -10 builder coming toward the end of the emp this spring and what a year its been for learning. Now in regards your questions and this is just my opinion:
1) TOOLS: Do not scrape the budget here, quality tools will make the experience enjoyable. As Todd has posted follow the link its probably all covered, I personally gathered a majority from a previous -10 builder here in the UK and then met a fellow RV builder and now a good friend whereby i gained some great hands on experience. I soon learned that i needed extra tools and must say that I have found Cleaveland / Browns & Spruce to be excellent. Youll find yourself ordering alot! But come around mid plans on the emp, your using everything youve ordered and confidence begins to grow.
MODS:
Your way ahead at the moment mate, spend time with the emp kit if after that you want to continue then concentrate on this subject as youll have enough to contend with during the first few parts of the emp as your learning the trade. Not sure what your background is but for me this was new ground, i worked on my old honda civic alot but this was completely new. Have you ordered the VANS Training kits as they are well worth the investment and time; you can learn using the drill, deburring, dimpling, rivetting , priming before even going near your airplane.
As others have said check out the other builder pages, i always do before starting a major piece (Justin Twilbeck / Good Plane Living/ myrv10.com )as there are always ‘lessons learned’ with this and if you can seek out a fellow builder not sure how easy that is in DXB but maybe when back home......just dont rush into it!
Good luck
James
All the best,
James, Prestwick
James McGee
Prestwick, Scotland
RV10
2018 Dues paid
Training kit complete
Emp complete
Wings under construction
Old 04-13-2018, 01:50 AM
Jim Frisbie Jim Frisbie is offline
Default Suggestions
Huzi
Welcome to the RV 10 club!
I suggest you talk to the folks at the factory to see if they will ship you the empennage kit without the tailcone parts. That would save you shipping on both the delivery and getting the completed parts to Texas.
The vert, HS, elevators and rudder are more than enough to keep you busy for your first year of building.
Jim Frisbie
RV 9A flying
RV 10 in process
Old 04-13-2018, 06:58 AM
rleffler's Avatar
Originally Posted by Jim Frisbie View Post
Huzi
Jim Frisbie
RV 9A flying
RV 10 in process
I disagree.....
Since you live just down the road, that probably isn't an issue. But for those of us that live farther away shipping and crating is a huge expense. The more you can bundle, the less expensive shipping will be.
Schedule is strictly based upon availability of time and skill set. My build goal was 20 hours a week. Most weeks I was able to hit that mark.
When I started, I was very novice with almost no experience. In other words, I was slow and made some mistakes that had to be redone. I just looked at my logs and I spent 369 hours on the entire empennage kit. Even if you just work 1 hour a day, you should be able to finish it in about a year.
If you want to SWAG what if may take you, look at the RV-10 build in mykitlog.com. mykitlog tracks time per task entry and summarizes them on the front page. Then the math is simple. Just divide by the amount of time you anticipate working each week to get an estimation on how long it will take.
Van's states that it will take 2200-2400 hours. My build took me about 3200 hours, but like mentioned, I'm not the fastest builder plus I had a fair amount of mods.
Bob Leffler
Old 04-13-2018, 07:35 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Build start
My recommendation is at least have a Skype discussion with an experienced builder before you begin your empanage build if you can’t wait to start it in Texas. The empanage can be a learning curve on quality building. However, you want to be further up the learning curve before you begin. There are many skills/ tips/tools that you will need to acquire if you want a quality job. PM me and I can try to help.
Al Girard, Newport, RI
N339AG
RV-9
