Old 04-11-2018, 10:07 PM
RandyAB RandyAB is offline
Default Measurement required for B&C alternator.
I’m looking at B&C backup alternators and there are a couple of options available. The unknown is how much space is available between the vacuum pump pad where the alternator will be installed and the firewall. TJ from B&C wasn’t completely sure that the larger of the two would fit. I believe he said 8 inches was needed. Does anybody know this measurement off hand or can they measure it if their cowling is off? It would be much appreciated!!
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 04-12-2018, 03:41 AM
Default Alternator
I can give you a data point.
I am using the Airwolf remote mount oil filter.
The BC-410 fits fine. There is not much clearance on the oil filter adapter but it is adequate.
The BC-462 WILL NOT FIT. It is larger in diameter and there is interference with the oil filter adapter. I had TJ actually send me one to try, so it is not an estimation.
There is plenty of room in the length dimension.
B&C have been great to work with and I highly recommend them...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 04-12-2018, 05:29 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Another data point
I have a Superior 0360 with B&C 462 H alternator. The oil filter and alternator have just enough clearance for ziplock bag at oil change
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 04-12-2018, 07:06 AM
rleffler's Avatar
rleffler rleffler is offline
I agree with Bob. I installed a SD-20, which has now been relabeled as a 40a. With the B&C spacers, it's a tight fit with oil filter. I highly recommend getting the B&C oil filter adapter to free up some space and make your oil changes less messy.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-12-2018, 09:14 AM
Thanks Bob. I did order the 90 degree adapter. It seems like this is the part that gives interference headaches though.
Randy P.
1st time builder
2017 dues paid
Old 04-12-2018, 09:22 AM
Iím using their oil filter adapter. TJ feels that with a spacer and drive extension that either one is a possibility. He wasnít worried about the diameter interference as much as room posteriorly. Not having built the engine yet, Iím not able to visualize what the issues are. Did you try the spacers and drive extensions? Iím not hung up on the larger alternator. At cruise rpm It seems that it doesnít really put out that many more amps.
Randy P.
1st time builder
2017 dues paid
Old 04-12-2018, 09:23 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Here are a couple of photos of the installation in my RV10 using the smaller 40A alternator
[IMG]IMG_0092 by Bill Peyton, on Flickr[/IMG]
[IMG]IMG_0093 by Bill Peyton, on Flickr[/IMG]
Bill Peyton
RV-10 - 875 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 04-12-2018, 09:40 AM
I can see how tight that is in the back. Are there any spacers or drive extensions in your setup?
Randy P.
1st time builder
2017 dues paid
Old 04-12-2018, 02:43 PM
Default Spacers
I am not using any spacers. I AM using the Airwolf remote oil filter adapter.
The interference, in my case, was from the diameter of the 462. The length would have been no issue.
Can't say anything about any other filter adapter. I opted for the remote filter early on, installed it, and never looked back...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Wiring...
Old 04-12-2018, 06:33 PM
My alternator is mounted directly to the vp pad without spacers.
Bill Peyton
RV-10 - 875 Hrs
WA0SYV
