Old 04-11-2018, 08:44 PM
David-aviator David-aviator is offline
Default RV-8 SOLD BUT STILL FLYING IT :)
Had great time yesterday flying the airplane I built and sold to a friend....shot 6 landings at 3 airports and then gave first check out ride to new owner.
My friend is good tail dragger pilot but thought he'd rather start in back seat to get feel of airplane. So off we went. Did steep turns, slow flight and glides in landing configuration.
Next flight may have him climb in front seat, have throttle in back seat but that's it.
Has anyone here landed the 8 from back seat? Have a notion to try it but don't want to wreck airplane.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2018 This place is worth it!
Old 04-11-2018, 10:00 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
With no rudder pedals, be quick to advance the throttle and go around! Maybe even practice some go arounds first.
Hey, my 1000th post! Cool
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 04-12-2018, 06:14 AM
ctennis ctennis is offline
I trained with Bruce Bohannon in an -8 and he sat back seat and definitely helped me with my first few landings (his plane is modified to have good full rear seat rudder pedals, not just the Vans kit).
For what it's worth, he told me he had no forward visibility when landing back there and relied solely on peripheral vision and feel.
N29213 - RV8 completed 2017
RV10 - tail complete, fuselage in progress
Columbus, IN - KBAK
Old 04-12-2018, 10:33 AM
luddite42 luddite42 is offline
You RV guys are spoiled. Vis from the back of an RV-8 is still better than any seat in a Pitts.
Old 04-12-2018, 06:04 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Iíve trained a couple guys in my backseat and itís perfectly doable, BUT, donít get behind because the stock rear rudder pedals suck.. thatís as nice as I could be..
Vis is really a non event if you have ever flown a Pitts or other similar biplanes. Look out the side and have fun..
Jerry "Widget" Morris
RV 8, N8JL, 2700+ hours
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018.
I just wish I could afford to live the way I do
Old 04-13-2018, 08:18 AM
Thanks guys, will go at this with some caution. I have the Vans pedals but they are not optimal. What is needed is an old fashioned grass field a mile wide and a mile long.
RV-12 Build Helper
RV-7A...Sold #70374
Old 04-13-2018, 09:07 AM
Tankerpilot75 Tankerpilot75 is offline
Thatís why God invented ďcrosswinds.Ē
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, GRT EIS, Garmin 340, 335, Dual 430s, FlightBox hard wired to WS, Dynon D10A with internal battery (backup EFIS)
Retired - Living the dream - And going broke!
Old 04-29-2018, 07:13 PM
Default New RV-8 Pilot
Have flown with new owner a few times with him in back seat doing air work and making simulated approaches. The machine has throttle and Vans rudder pedals.
His control of airplane has been very good, he can see ASI over my left shoulder and has done very well maintaining speed, calling for flaps, flying right down to flare and going around. Did not want to risk landing from back seat but it probably would have worked out with limited visibility.
Today we swapped seats. We took our time making sure check list was completed, talked about take off with nearly full tanks and 2 people. Once airborne did some air work, made several approaches to farm grass strip, did not land not knowing surface condition. The decide to head back to Troy Airpark for landing on 1700' grass, he has flown out of this airport and knows it well.
Landing was excellent so I got out and briefed on how airplane would be different with no one in back seat and off he went. Shot 4 full stop landings and finally called it a day back at hangar.
He had the typical RV-8 grin....it was a good day all around.
RV-12 Build Helper
RV-7A...Sold #70374
