Old 04-10-2018, 08:29 PM
theduff theduff is offline
Default WTB Millenium 320 cylinder core
I’ve got 3 good rebuilable cores but need a fourth ! Truth is 2 cores have rejected due to cracks in the exhaust port area. Hopefully somebody has a good Superior Millenium cylinder core they can part with for a reasonable price.
Duff
760-805-6641
Old 04-10-2018, 09:47 PM
lr172 lr172 is offline
Originally Posted by theduff View Post
Iíve got 3 good rebuilable cores but need a fourth ! Truth is 2 cores have rejected due to cracks in the exhaust port area. Hopefully somebody has a good Superior Millenium cylinder core they can part with for a reasonable price.
Duff
760-805-6641
I have 6 cores, but they are from a 540. I believe they are the same as the 360's, but not the 320's.
N64LR
RV-10 in progress
Old 04-11-2018, 06:08 AM
RV6_flyer's Avatar
Duff
760-805-6641
Wide Deck or Narrow Deck?
Wide Deck uses Hex Nuts to hold the cylinders to the Case. The Narrow Deck uses Internal Wrenching Nuts (allen style) to hold the cylinders to the Case.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 04-11-2018, 04:09 PM
Default 0-320 Millenium cylinders
Normally we always assume wide deck unless otherwise stated. Thatís probably because Lycoming came out with the wide deck architecture in the late 60ís. Nothing wrong with the narrow deck but most of them have are very high time but I still build them occasionally.
Duff
Old 04-11-2018, 04:17 PM
Default 0320 Millenium WD cylinders.
Yeah Larry 360 540 interchange but not the 320ís. I did however take some angle valve 360 cylinders and put the heads on 320 barrels for a wide deck angle valve 320. Took the remaining pieces and put the 320 heads on the 360 barrels and had a nice set of parallel valve 360 cylinders. ( the 320 heads are identical to the 360 heads.) Old school hotrodders did the same thing with GO-480 cylinders but they were only made with narrow deck architecture.
Duff
Old 04-11-2018, 08:16 PM
RV6_flyer's Avatar
Duff
Never assume.
Narrow Deck cylinders are still being manufactured. I have four Superior Millenium 320 cylinders in my hangar on the shelf. They are Narrow Deck cylinders. I also have four ECI 320 Narrow Deck cylinders with S/N not on the AD list that were manufactured after the AD was issued sitting on the shelf. So I have 8 narrow deck 320 cylinders sitting on the shelf and only four 360 Wide Deck Cylinders on the shelf.
The Narrow Deck cylinders are still being manufactured so when you ask for cylinders, make sure you know what you need or want else someone may provide what you did not want and cannot use.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Old Yesterday, 02:57 PM
4991H 4991H is offline
I got 3 0320 Superior wide deck cores. Their cracked bad in the exhaust port also. Doubt they are rebuildable but I can send you pics if your interested. 1850TTSN.
Old Yesterday, 08:26 PM
Sdemeyer Sdemeyer is offline
I have 2 lycoming o320 cylinders if those would work. No idea if they are rebuildable as I just bought new ones instead of messing with these. They look OK to the naked eye I think they have about 700 hours on them. Let me know if your interested or want pictures. They are just big paper weights to me and taking up valuable space in my hangar.
Scott DeMeyer
Olympia,WA
RV6A quickbuild, Flying as of 10-14-2017
Mustang II Built and Flying
