Old 04-10-2018, 02:24 PM
AGORV AGORV is offline
Default 3-blade propeller MT
question I have in mind of monatre on my RV7 a 3-blade MT propeller. do you know how it works with RV7?
Old 04-10-2018, 02:42 PM
Default Welcome to VAF
Agostino, welcome to VAF
Old 04-10-2018, 05:23 PM
mike newall's Avatar
Email sent
Donated in 2018
Old 04-10-2018, 07:37 PM
Super Moderator
I had one on my rv-7A and really liked it.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 04-10-2018, 08:51 PM
Jpm757 Jpm757 is offline
I installed a new IO-360M1B and MT 3 blade from Vans on my -7, with the new 59B blades. I am VERY pleased with this combination after 100 hours. Takeoff and climb performance is outstanding, and I am dead even with my hanger partners 180/CS Hartzel RV8 in climb and cruise.The MT was incredibly smooth BEFORE I had it balanced. Weight and balance numbers came in right where I had hoped. A little pricier than the Hartzel, but prop includes a beautiful painted & installed spinner assembly. Literally bolt the prop on and you're done. Have flown in rain, soft fields and frozen lakes with no blade erosion whatsoever. Also using the MT governor supplied with Vans FWF kit, dead on at 2700 rpm/no adjustment was required. 12 week lead time on delivery from Germany and the prop is shipped to a local dealer for assembly and delivery.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 170+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 04-11-2018, 12:02 PM
thanks to all and I apologize for the question a bit out of place.
sorry...
Old 04-12-2018, 09:07 AM
jdeas's Avatar
jdeas jdeas is offline
Default Very happy with mine
In my case I can out climb but have lower top speed than other RV7 aircraft I have flown with. This is in line with much of what I read on this forum as well.
We are taking a knot possibly two at low alt so the difference is rather small. I also just like the look of a 3 blade
If anything, the three items I would suggest you consider are:
1) I feel the 3 blade composite reduces vibration a bit over metal 2 blade
2) The light weight of the prop and modern starters shifts the CG weight back enough where you will hit aft CG limits before gross weight unless dealt with during the build.
3) It will be harder to remove the cowl for service
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
