Old 04-10-2018, 08:17 PM
what about a small plate to cover the center, between the pipes?
Old 04-10-2018, 08:24 PM
Kyle Boatright Kyle Boatright is online now
Would VG's help at the inflection point?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-10-2018, 08:27 PM
Aluminum Aluminum is offline
I'd bet $1 that they would reduce net cooling flow. Would be interesting to stick a pitot or two in the opening and burn some avgas in the name of science.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2018 dues worth every penny
Old 04-10-2018, 08:32 PM
BillL BillL is offline
Go to the vetterman website and look at Larrys work on his afterbody with twin exhaust pipes. The got 4 mph or so IIRC. RV7A, but should apply.
My exit velocity on my SJ (7) is so low that the lower cowl pressure is nearly equal to static pressure up to 170 kts. I just have other issues now to complete phase I, so appreciate your project and sharing.
Note the air wants to come back to the centerline, so a narrowing of the afterbody should help.
edit:
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 04-11-2018, 01:02 PM
czechsix's Avatar
czechsix czechsix is offline
I built progressively smaller exits to determine what exit area was really necessary. This one is the last in the series, extended four inches rearward to make the exit smaller due to ramp taper. I could keep the IO-390 under 380F CHT with this size, 1.625" high, but oil would push 215 if run hard. It would not have worked for slow flight and long taxi (like into HBC at OSH), as I would not have been able to keep oil under the limits. With a minimum flyable exit area established, I added a variable exit panel, the long term goal. Note the panel center-pivots, so half the additional exit adds no frontal area when open. It's good for about 16 sq in. Lower cowl internal pressure rises significantly when closed, meaning velocity rises in the primary exit.
Dan, have you tested the 'variable exit panel' (aka cowl flap?) during hot weather and/or long ground runs like at OSH to confirm that it provides adequate cooling under those conditions? Or is that testing part of what you refer to by 'long term goal'? I've considered reducing the exit area on my RV-14 to try to pick up some speed (by all accounts it has more cooling than needed), but I'd rather not mess with a cowl flap and prefer to find a fixed exit area that provides an acceptable compromise in all operating conditions...
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 04-11-2018, 01:40 PM
bk1bennett's Avatar
bk1bennett bk1bennett is offline
Originally Posted by Onewinglo View Post
My partner and I felt we were overcooling our O-360 XP so he designed and built a sub-cowl to reduce the exit opening and reduce cooling drag. We expect the reduction in exit opening will increase the CHT and oil temp. Testing has been limited due to weather and schedule but we have noticed a very modest increase in CHT and oil temp. I tufted the belly around the exit and recorded the flight to get an idea of how the sub-cowl disturbed the airflow. The test was at 3000' and 160 - 170 mph. A link to a short video is attached.
RV-8 with custom plenum and Sam James Cowl
Carbureted 360XP with Mags
FP Cato 3 bladed prop
https://youtu.be/qlX7UDfP8Ko
I too am an aero engineer and I agree with Steve Smith's take that your aft-facing surface is too steep to keep the flow attached. However, based on my experience, you have done a pretty good job of keeping the flow-separation damage to a minimum. The separation bubble is not very big and is not very strong. You could easily do much worse!
Unfortunately, anything you do to add frontal area requires a lot of length to smooth it out downstream to avoid flow separation. The fuselage is a good example. You rapidly increase frontal area, then you spend about 10 ft or more fairing it back to a small cone to keep drag low.
Did you substantially increase frontal area in the forward cowl? I am a bit uncertain on how extensive your modification is to the outer moldline of the RV. It seems like you modified two cowl parts ... is that correct?
Latest Annual Donation Date: 11 Apr 2018
RV-14A Empennage Kit #140396
Old 04-11-2018, 04:52 PM
Onewinglo's Avatar
Onewinglo Onewinglo is offline
Default No frontal area increase
No we did not change the frontal area of the lower cowl. We simply added the sub cowl and changed/reduced the exit in an effort or reduce cooling drag. The link below has a couple images that will help in my explanation.
Thanks for the comments!
https://photos.app.goo.gl/wUgNCDJEEkjXS5A32
https://photos.app.goo.gl/GRXanzkgtVp85Y223
https://photos.app.goo.gl/PiLQ3QxUtDN8iQIz2
JP White
RV-8 Phase 1 Complete!
Cessna 170A SOLD
2018 dues Paid
A new pilot having fun!
Old 04-11-2018, 05:03 PM
Onewinglo's Avatar
Default Inflection Point?
Kyle, I hate to display my ignorance, but is the inflection point on the following edge of the exit opening?
Thanks!
JP White
Cessna 170A SOLD
2018 dues Paid
Old 04-11-2018, 06:17 PM
Thanks!
I may have used an inappropriate term, but what I was referring to is the sharp radius I *think* I see where your new exit ramp turns parallel with the direction of flight.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-11-2018, 08:06 PM
DanH's Avatar
DanH DanH is online now
Yes, it has seen all conditions, including OSH.
We can talk after S&F if you like.
Dan Horton
RV-8 SS
Barrett IO-390
