Old 04-09-2018, 10:05 PM
ben barron ben barron is offline
Default erratic CHTL
In the last 15 minutes of a 2 hour flight the CHTL started jumping between 147 and 0 erratically. The CHTR was stable at 181 and EGTL/R at 1360, Any ideas?
B2RV12
Old 04-09-2018, 10:27 PM
DHeal DHeal is offline
Most likely a loose or corroded wire or connection. Wiggle the CHTL sensor connection (under left front cylinder head) to see if you can duplicate the erratic reading.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 710+ hours (as of Dec 2018)!
VAF donation through June 2019.
Old 04-10-2018, 05:58 AM
BigJohn BigJohn is offline
Clean up the connectors and spray with a contact cleaner. I have some at the hangar, I think the name of it is something like Deox-It.
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 04-20-2018, 11:57 PM
I tried all the above to no success. In testing today I discovered the erratic reading even with the engine off so there was nothing vibrating to jiggle a loose connection. Any other ideas?
B2RV12
Old 04-21-2018, 02:46 AM
Certainly sounds like a bad thermocouple. My EGT thermocouple failed in this exact mode. One source for the new part is... https://www.ebay.com/itm/Rotax-912-9...VXPF30&vxp=mtr
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 04-21-2018, 05:29 AM
Swap L and R and see if trouble follows the part.
Old 04-21-2018, 08:02 AM
AirHound AirHound is offline
Thank you for info. Another small issue ?
When sitting engine off the left indicates 20 higher. When operating both gauges come close? Any ideas as to why?
Doug
Old 04-21-2018, 07:42 PM
Thanks for the tips, now before i remove it to cross check....How would i find the torque of the thermocouple (i tried to find it in the Rotax installation and maintained electrical manuals but have not been successful )?
B2RV12
Old 04-21-2018, 08:25 PM
For a quick trial leave thermocouples in place and switch the wires. Perhaps use alligator test leads to temporarily span wires from one side of engine to the other. Don’t think I’d fire up the engine but this might be a good static test to isolate if one thermocouple is bad.
Alligator test leads…
Hinckley, Ohio
EAA #499867
Old 04-27-2018, 11:11 AM
Default CHT install torque?
Thanks for all the help.
I wanted to confirm the torque to replace the CHT in my RV12 with Rotax 912 ULS. Would it be the same as the oil pressure sensor? I could not find a similar chart for the CHT in the Rotax manuals, the Installation Manual (page 148 of 203) shows oil pressure sensor torque at 133 in. Lbs.
B2RV12
