Old 04-09-2018, 07:07 PM
Driving '67 Driving '67 is offline
Default Rudder pedal Bearing Block
Iíve been working on the installation of my rudder pedals and the top portion of the bearing block appears to be too thick to fit between support angle and the rudder bar. It looks Iím going to have remove about .075Ē of material to fit without binding. Has anyone else bumped into this? To date everything has fit perfectly so Iím wondering if Iím missing something. Both ends of the rudder pedal blocks went into their respective holes with no issues or binding.
RV 14A wing/tail/fuselage done
Doing the avionics/wiring harnesses
G3X/GTN650/GTN625/GTX45R
Waiting for warm weather to do the canopy
Serial 140118
Old 04-09-2018, 07:29 PM
mturnerb mturnerb is online now
I had to make a similar adjustment. Bungled it the first time, re-ordered.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 04-09-2018, 08:10 PM
JHartline JHartline is online now
Adjusted mine too. Donít forget the washers in between the blocks.
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 04-09-2018, 08:24 PM
Thank you Gentlemen .... much appreciated.
Serial 140118
Old 04-11-2018, 09:23 AM
rapid_ascent rapid_ascent is offline
I think this falls into one of those build order issues. Sometimes it appears the instructions don't always call out the best build order. I haven't looked at the 14 instructions so I'll throw out that disclaimer too. I think on mine I marked the hole locations on the firewall stiffener, bolted the bracket to the rudder pedal assembly, aligned the bracket holes as best I could to my marks, clamped the bracket to the firewall stiffener and match drilled.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-11-2018, 12:54 PM
salto salto is offline
In a practical sense a bit of resistance there is not an issue.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 04-11-2018, 08:46 PM
The bearing block bolt holes match up to the support angle perfectly. The block is just too thick and if forced will probably cause the firewall to bulge. As the other posters mentioned they had to remove material prior to final fitting. As a first time builder Iíve got used how refined the RV14 kit is.
Serial 140118
