Old 04-09-2018, 05:19 PM
JHartline JHartline is offline
Default Antenna cable routing
Curious how folks are routing antenna cables, mainly to the comm antennas on the bottom of the aircraft. Does anyone have a nice pretty method for running the coax cables through the cockpit? I plan to run the GPS and XPDR cables through the tunnel but I think the comms and nav would be better run along the sidewalls and I want to conceal/protect them as much as possible. That will require drilling a hole in the control column cover. No biggie there but I want to explore options before I start drilling holes.
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 04-09-2018, 06:46 PM
mturnerb mturnerb is online now
Given the proximity of the comm antenna locations in the bottom skins, and easy routing from there through to the tunnel, why would you go outboard? The lightening holes in the cover ribs lead directly from the bottom skin locations to the tunnel area.
I haven't gotten that far along in my build but that looks like the easy way to me. If I'm missing something, apologies.
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 04-09-2018, 07:48 PM
KeithB KeithB is offline
I ran both the Com antenna coax through the center tunnel with easy install and no operating issues.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, Phase I compl Apr 3, 2017, >220 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 04-09-2018, 07:52 PM
The tunnel is best but there is some requirement to separate the GPS antenna cable from the others and I was going to run it there. I need to ask Garmin about the distance requirement.
James Hartline
Carrollton, GA 5GA2
T-Bolt IO-390
Maule MX7-180
Old 04-09-2018, 09:45 PM
n982sx n982sx is offline
I ran the comm, 625 GPS, transponder and ADS-B in antenna cables through the tunnel. I've got 150 hours on it now and have not had any difficulties.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 04-10-2018, 05:18 AM
Nothing like real world data. Thanks Bob!!
James Hartline
Carrollton, GA 5GA2
T-Bolt IO-390
Maule MX7-180
