Old 04-09-2018, 08:10 AM
JDA_BTR JDA_BTR is offline
Default Is grease like a primer war?
Iím at the step where I grease the nose wheel spindle. It says use marine grease. Donít have that but I do have a big tub of mobile synthetic mhc100. Any reason to not use the mobil?
Ser 104142, RV-14A
N1463
Final Assembly....
Old 04-09-2018, 10:02 AM
These are experimental aircraft.... you can use Vaseline if you want.
The water proof grease has shone to provide the best performance in areas that can be exposed to water, like the nose or tail wheel fork.
The manuals try and provide info specific to what Van's does, based on experience. It does not mean it is the only way, and it is always possible that someone will discover something better. In this instance, the water proof grease so far the best known option.
Scott McDaniels
Hubbard, Oregon
