Old 04-08-2018, 06:35 AM
Davoakes@att.net Davoakes@att.net is offline
Default degrees swing of the rudder Rv-14
Would some one please tell me the degree swing of the RV-14 Rudder.
I want to install a rudder stop as I build the Vertical Stabilizer. I want to be sure it is correct before installation.
Daveoakes
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 04-08-2018, 06:48 AM
control control is online now
http://www.vansaircraft.com/pdf/lett...ons_Letter.pdf
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 04-08-2018, 06:50 AM
mturnerb mturnerb is offline
The rudder stops get adjusted based on clearance from the HS/Elevators. I test-fit mine and ended up adding the extra layer to the rudder horn contact area to get just a bit of extra clearance. I don't think you can properly adjust rudder travel without the full empennage mounted so you can check this clearance. See section 11, page 09.
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 04-08-2018, 08:54 AM
Bavafa Bavafa is offline
Same here, I even added a bit extra room between the corner of the elevator and rudder for extra margin of clearance
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 04-08-2018, 03:21 PM
Thanks for the quick replies.
Blessings
Daveoakes
RV-7A N1243A Sold
