I wasn’t aware of a new kit for the extra landing light. I basically ordered a copy of all the parts I used on the right wing landing light. I’m guessing they are referring to the “sync wires” needed to let the two lights work together such as the wig wag function. If you look at the wiring schematic that came with your Aeroled landing light, you will see. Without going back to look at my own, I think a sync wire on one wing is connected to the blue wire on the LL and in the other wing a sync wire is connected to the green wire on that LL. One is essentially a slave to the other.
I found out about the new iS configuration just in time. I hadn’t closed up my left wing skins yet and I was able to sell my old style fuselage kit and ordered the iS version. So having extra electrical capacity let me add the second landing light. Also, I added the Angle of Attack kit before I closed the left wing skins. Hope this helps. Good luck!
RV12 - building
Empennage finished
Wings finished
iS Fuselage in progress
ULS Fuselage kit - SOLD
Farmer - corn & soybeans
Firefighter
2018 Dues Paid
Knoxville, IL
