Old 04-03-2018, 05:45 PM
Stockmanreef Stockmanreef is offline
Default Wire Harness: when to install
I purchase the common wire Harness WH-00125 from Stein. Is there a preferred time to install? I assume before Section 42--Misc section that covers up seats and stuff in baggage area. I am at the Canopy section, which I will start on soon, but will wait until if it warmer to work with the plexiglass.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 04-03-2018, 07:29 PM
JHartline JHartline is offline
Default Harness
Ken,
You could do it either way. I ran mine after I had the floorboards, etc installed. Slightly painful but not too much drama. Some of the heat shrinks are in just the wrong place and interfere with grommets. It would be easier to reposition them if everything was exposed. Also, Iím sure running additional wires for extra goodies would be easier as well.
Not sure if the harness would interfere with riveting. You may want to check that.
James Hartline
Carrollton, GA 5GA2
RV-14 - Hoping to fly sometime this century. Almost done.
T-Bolt IO-390
Maule MX7-180
Old 04-03-2018, 08:41 PM
Hey Ken, we have a new project in Lansing later this year. I will have to come by and see your project again. As for the wiring harness, I would get it in as early as you could. As long as you don't put any connectors on the ends of the wires, it should be easier than fishing them later. If you have to back out and put back in a few wires, I think it would be worth it.
It is probably worth it to add a wire or two to the cabin and behind the seats just in case you add something later.
Have fun. Hope to see you later in the summer. Maybe I will bring my 9A out!
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
