Old 04-03-2018, 04:35 PM
D&M Dan D&M Dan is offline
Default Condition inspection, fuel tank removal.
Reading the maintenance Manuel to prepare for my first condition inspection. Among things listed to remove is the fuel tank. I am wondering why. Iím not seeing any specific reason to do this. I believe once drained the outlet screen can be removed from below and cleaned and inspected.
Am I missing something? Seems like taking those frangible bolts in and out may be a potential problem and when I built the airplane I installed the floor and tunnel access panels so as I would not need to remove the fuel tank.
Dan
(Waiting for SB parts and spring weather)
N930DD (Registered)
Home Field KSDC
Paid 2017
Old 04-03-2018, 04:51 PM
alexe alexe is offline
No, I donít think you are missing anything. No need to remove the tank in your case.
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2018
Old 04-04-2018, 05:48 AM
TomVal TomVal is offline
Dan
Not required if you have the modification above to include the split aft baggage compartment panel. Part of the annual inspection is to inspect the flaperon torque tube attachment to its respective bell crank assembly for security. The right fitting can be inspected by holding a mirror and flashlight behind the baggage compartment bulkhead looking forward. You can view the fitting through a lightning hole.
Hope that made sense?
Regards,
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 04-04-2018, 08:00 AM
Yes, Makes sense.
Thank You
N930DD (Registered)
Home Field KSDC
Paid 2017
