Old 04-01-2018, 05:26 PM
Jpm757 Jpm757 is offline
Not familliar with the -10, are there any rudder return springs installed?
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 170+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 04-01-2018, 05:40 PM
Auburntsts's Avatar
Originally Posted by Chippster1 View Post
Will check breakout force next
I believe 28lbs at the axle nut correct?
Close-- it's 26 lbs
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-01-2018, 05:50 PM
No return springs.
The builder's manual shows where to apply the force/measurement. My recollection is that it was at one of the lightening holes (which is convenient for attaching a spring gauge), but I could easily be wrong about that. EDIT: SEE COMMENTS BELOW. USE AXLE
Old 04-01-2018, 06:09 PM
Chippster1 Chippster1 is offline
I would love to see the video of the nose gear castering in flight
Does anyone know where it is?
Also, does anyone know why it would move one way or another?
Could it be a spiral in prop wash? I would think it would just want to weathervane in the relative wind, thus straightening itself out. I must confess I am perplexed
Old 04-01-2018, 06:36 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Here, let me Google that for you:
"Before we tightened it, we shot a video and I was amazed to see just how much the nose wheel will turn due to prop wash!!"
http://n42bu.com/post/2013/09/24/Nose-wheel-shimmy.aspx
Carl N.
Arlington, WA (KAWO)
RV-8, 435 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 04-01-2018, 06:38 PM
9GT's Avatar
9GT 9GT is offline
If the nose wheel is not aligned straight when it lifts off the ground, it may be skewed left or right and not center, creating a trim effect. Breakout force is important. I would disassemble, clean and lubricate, and reassemble using the axle hole as the breakout force point of measure, not a lightening hole. Doing a lightening as the point of measure will cause an erroneous calibration.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 04-01-2018, 07:32 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Originally Posted by BobTurner View Post
No return springs.
Definitely 26 lbs at the axle - sheet 46-06
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-01-2018, 08:45 PM
Get a chase plane and have a look see.
Jake
Old 04-01-2018, 09:24 PM
Default Or
Get a GoPro camera an video a flight. There are a couple of guys that make mounts for the camera that screw into the wing tie down hole...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 04-01-2018, 10:04 PM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
I had the same problem at around 70 hours. The belleville washers loosen up after a while.
Here's a picture of what it looked like on my plane:
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 450 hrs
