Old 04-01-2018, 12:41 PM
727TT 727TT is offline
Default Marvel-Schebler Carburetor
I was reviewing the Superior Engine Service bulletins and noticed a SB for the float It says to inspect every 30 days until replaced with a new foam float.
Has anyone had to replace their float as a result of this? I plan to call Superior on Monday with my carburetor serial number to see if they can tell me what type of float is in my carburetor.
Thanks!
Steven
RV727TT
Old 04-01-2018, 02:54 PM
snopercod's Avatar
I think these days you're suppose to have the blue epoxy floats.
(2018 dues paid)
Old 04-01-2018, 05:02 PM
Note also there is a version of the metal float which is NOT affected by the current or previous M-S Service Bulletin. When I had my carb IRAN'd prior to first engine run the overhaul shop asked if I wanted to spend the $400 for the blue float or $115 for the metal float. After a good chat it was decided I would go with the metal float, a float which has given them zero troubles, rather than the blue float that might end up with the same as the plastic float it's replacing.
The OH shop manager summed it up with words that went like this... "The plastic float was installed in response to a SB to get rid of defective metal floats. A few years later we're replacing their gee-whiz plastic float with another unproven plastic float while a proven metal float exists. It's stupid to think the new blue float is worth the money they charge when they said the same thing about the plastic floats that sink."
'Nuff said - I was convinced and went with the proven metal float.
Old 04-01-2018, 05:21 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I think some of the old metal floats leaked and that was why the plastic ones came along.
However, as the old saying goes - "Sometimes the cure is worse than the problem"
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-01-2018, 08:05 PM
longranger's Avatar
longranger longranger is offline
I would think they would have this sorted out by now. This Marvel-Schebler float thing has been going back and forth at least since the 1980ís.
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 04-02-2018, 06:16 AM
snopercod's Avatar
It's pretty simple and not very expensive ($120) to change floats yourself. Blue Epoxy Float Kit from ACS.
(2018 dues paid)
Old 04-02-2018, 07:58 AM
rv7charlie rv7charlie is online now
It's not uncommon for aircraft ADs to pop up right around the time of (after) a change in ownership of the design/production certificate. Just sayin'.....
Old 04-02-2018, 02:57 PM
Default Marvel Schebler Carburetor
Thanks for the feedback and help!
