Old 03-31-2018, 12:13 PM
JDA_BTR JDA_BTR is offline
Default Engine mount wrong?
The upper corners of my engine mount seem wrong. There is 1/2 ID tube where I think there should be 3/8 so the bolt wallows around. Also an AN6-24 is too short. Any ideas? I asked Vans already but quicker answers here!!!
N1463 seems a good number....
Old 03-31-2018, 12:20 PM
It is purposely over sized.
The only hole diam. that matters structurally is the one in the flange that mates with the firewall.
Scott McDaniels
Hubbard, Oregon
Old 03-31-2018, 01:14 PM
Jake14 Jake14 is offline
hard to tell with the angle, but it looks like my (14A) upper left tube might be shorter than the one in your pic, but upper left and right bolts are AN6-26A on the taildragger
RV-14A #140158 flying
Old 03-31-2018, 01:31 PM
Scott, is there some manuf variability in the depth of that mount tube? My right and left upper corners both need a 25 or 26. The plans are usually dead on. I for sure have the right bolt sized it on the size chart.
Old 04-02-2018, 12:30 PM
The production drawing shows that the upper two bushings should be 1.25" long (beyond the face of the flange washer), and the lower 4 bushings should be 1.0" long.
I have not heard of any other complaints about the specified bolts being too short.
Scott McDaniels
Hubbard, Oregon
Old 04-04-2018, 02:56 PM
Measured my upper mount bushings and mine measure just shy of 1.5 inches past the big washer or 1-5/8 from the firewall. Thatís an extra 1/4 too long. So do I just upsize the bolt length or get another mount?
Old 04-10-2018, 06:20 PM
Final answer on this was the tube diameter is right but my tube is 1/4 too long. Up two bolt sizes and carry on I was told.
Old 04-10-2018, 06:42 PM
maybe someone welded a taildragger tube on a tri-gear mount. taildragger upper tubes are longer for some reason
