Old 03-31-2018, 09:10 AM
Chris Cooper Chris Cooper is offline
Default Section 25-02 - bulkhead bars
You have to double flush rivet the Bulkhead Bars together but nowhere does it say to countersink them? Have I missed something? I have read it 20 times now....
Chris Cooper
G-CRVC
www.vansrv14.uk
Old 03-31-2018, 09:49 AM
control control is offline
Checked my blog but no mentioning of the problem and nothing in the master list of common errors either :/
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 03-31-2018, 09:52 AM
Thanks, Iím assuming they have to be countersunk to allow them to be flush riveted though. Seems like a stupid question but Iím paranoid of an expensive mistake...
Chris Cooper
G-CRVC
www.vansrv14.uk
Old 03-31-2018, 09:57 AM
The farther you get in the plans, the more little details are left out--------this is an educational process and the need for step-by-step "hand holding" is not as great as when you first start.
Old 03-31-2018, 10:06 AM
Which is understandable except all the other double flush riveting on the next 2 pages has countersinking mentioned.
Chris Cooper
G-CRVC
www.vansrv14.uk
Old 03-31-2018, 10:09 AM
One is so spoiled with not having to think so in the few instances that you do, as a first time builder you hesitate.... Happens more often in the later parts, I get scared when I read sentences like "Except as noted in Figure 1, install an alternator and alternator belt onto the engine as described in the alternator documentation."
RV-14 kit #140138
Old 03-31-2018, 11:08 AM
JHartline JHartline is offline
Default Donít forget section 5
Chris,
Vans frequently instructs you to do a procedure that is explained in section 5. I have had to remind myself that if they tell me something in section 5 they often expect not to have to repeat themselves later on.
In this case, double flush riveting is discussed at length in section 5.8 including the countersink process.
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
