Old 03-27-2018, 09:18 AM
KazooRV-9A KazooRV-9A is offline
Default Close riveting on 9 aileron
I'm having trouble with this last rivet on the ailerons. I've read that some use a pull or flush rivet here.
[IMG]https://i.imgur.com/O35qLLe.jpg?1[/IMG]
What P/N pull rivet would I use? and can it be used with the dimpled skin?
Andy C.
Old 03-27-2018, 09:28 AM
Default Factory says
I got permision from Eric at the factory to use MK319s there.
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 03-27-2018, 09:40 AM
Will an MK319 work if the skin is dimpled?
Old 03-27-2018, 10:15 AM
Default yes
Same rivets as used on the bottom skin, so ya they will work for the dimples. The pilot hole needs to be enlarged slightly just like when attaching the bottom skin.
John S
Fuselage 30%
Old 03-27-2018, 12:08 PM
mturnerb mturnerb is online now
#34 or #33 bit or reamer will work for MK-319BS.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 03-27-2018, 01:22 PM
I'm building the flaps now also, that do use the MK319 pull rivets on the bottom skins, and I assumed that you do not dimple those installations?
Old 03-27-2018, 01:28 PM
Arie's Avatar
Arie Arie is offline
The MK319 rivet is a counter sink rivet, therefore it must go into a dimpled/ countersink hole
Old 03-27-2018, 01:33 PM
With further looking, I see that! Needs a dimple.
Good to go slow and check things out.
Can these blind rivets also be used for the close locations on the flap top skins?
Old 03-27-2018, 09:12 PM
VA Maule VA Maule is offline
I did a little creative grinding on old ax head to use as a bucking bar with quite good results on my 8 .
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
