Old 03-22-2018, 08:52 AM
sjhurlbut sjhurlbut is offline
Default Fastback RV8 panel pics
Working on my panel and canopy frame at same time. RV8 with Showplanes fastback.
I'm looking for how much of the instrument panel gets covered when the canopy is closed. The front brace of the canopy frame sits slightly in front of the panel. I've seen panels with little consideration of this and instruments right up to the edge while the demo RV8 fastback has a 1" space all way around.
So you fastback guys:
When your canopy is closed how much panel is covered and how much do I need to leave in order to not obscure anything?
Pics would be nice here
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1
Old 03-27-2018, 08:13 PM
BHunt BHunt is offline
Contact Jesse Saint. I have the showplaces fastback and canopy and he did my panel. Should still have the mock up with edge clearance.
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 03-27-2018, 09:36 PM
Chris Engler Chris Engler is offline
I don't have dimensions handy but this pic gives you a general sense of the canopy frame "overlap" on the panel. When closed, the bottom of the frame just covers the 8/32 pan head screws around the top perimeter of the panel....the dimension widens from the top to the sides (guessing 3/4 inch at the top to 1 1/2 inches at the sides.
For reference, the two screens are 10.4 inch HXrs and the radio is a GTN650. Note that the panel itself is a single piece of 1/8 inch thick aluminum rather than the standard 3-section panel from Vans.
Chris Engler, Greene, NY
RV 8 Under Construction (N184CE Reserved), Showplanes Fastback, Superior IO 400; Dual 10.4 HXr
Kitfox 7; Rotax 914, Built and Sold
VAF donation gladly paid through December 2019
Old 03-27-2018, 09:46 PM
Default Great
Thank you!!! Cutting tomorrow
Enzo Ferrari
Steve H
Cold Lake, Alberta
Old 07-13-2018, 09:37 AM
walter's Avatar
walter walter is offline
Default Showplanes Panel Overlap
Here are a couple of pictures which show the amount of overlap on the panel of the forward transverse rib on the Showplanes canopy.
http://tondu.com/rv8a/?p=2124
Walter Tondu
Current RV-8A Build Log - Fastback, XP-400, G3X Touch
Prior RV-7A Build Log
