Old 03-22-2018, 02:09 AM
Mikeandmaz Mikeandmaz is offline
Default Forming Rudder Lap joint
Iíve seen from another builders blog that forming the Rudder leading Edge lap joint bend is quite difficult if done as per the plans. So I thought Iíd do the bend before I start riveting it all together. In Section 5.10 it states the bend should be about 1/4 inch in. This would put the bend through the holes on this occasion, so would I be right in assuming the bend needs to be closer to the edge in this case?
Apologies for such a mundane question, Iíll try for a better one next time.
Mike
Empennage arrived
VS completed
Rudder completed
HS completed
Elevators in progress
#140425
Donation paid 2018
Old 03-22-2018, 08:40 AM
mturnerb mturnerb is offline
Are referring to an edge break? If so it's easier to do before most assembly but not that hard to do at the point you're ready to roll the leading edges (that's the HARD part).
I like this edge roller tool: http://www.cleavelandtool.com/Edge-F.../#.WrOvqpMbO9Q
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 03-22-2018, 11:41 AM
Yes I guess thatís another name for it. Just wanted to know if there was a minimum distance from edge. As plans recommend 1/4 inch and that would put it through the holes.
Empennage arrived
VS completed
Rudder completed
HS completed
#140425
Donation paid 2018
Old 03-22-2018, 12:00 PM
Understand - I just ran the edge roller over the holes and didn't think about it too much. You may want to check with Van's as I wouldn't want you to think I'm an expert. The tool does about 1/4" as well.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 03-22-2018, 12:01 PM
Through the holes is actually the ideal position for a break bend line.
Scott McDaniels
Hubbard, Oregon
Old 03-22-2018, 01:35 PM
StressedOut StressedOut is offline
At the rudder leading edge you're using pop rivets so this piece of advice doesn't really apply. However, when you're putting in an edge break near dimpled holes (think rudder trailing edge), do the break before you dimple.
I did it after and I had a hard time getting the roller tool past each dimple. After I finished I had to re-dimple all of the holes because it flatted them slightly. In the end it worked, but save yourself the extra effort and do the break *before* dimpling.
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" is the opposite of "find". "Loose" means "not tight".
Old 03-23-2018, 02:24 PM
Thanks for the advice guys. Edge tool on order from Cleveland.
Empennage arrived
VS completed
Rudder completed
HS completed
#140425
Donation paid 2018
