Old 03-19-2018, 01:02 PM
mike newall's Avatar
Default Cooling fans
Exciting day - powered up for the first time !
The two fans on the base of the sub panel - anyone know if they are designed to run all the time, or only when the Skyview fans run ?
Everything else looks OK, but those fans aren't running.
Donated in 2018
Old 03-19-2018, 01:15 PM
rolick22's Avatar
rolick22 rolick22 is offline
If I remember I think they are on the Fuel Pump Bus.
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished (need to add the panel cut out)
Wings finished (need to add the left landing light)
iS Finishing Kit In work
iS Fuselage Finished
1st GEN FUSELAGE SOLD
Serial#12-0864
N864DR Reserved
Old 03-19-2018, 01:36 PM
pstraub's Avatar
pstraub pstraub is offline
They should turn on with the Master Switch, but if you have the 5A fuel pump fuse removed, they won't run (same circuit).
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
120 hours and counting.....
Old 03-19-2018, 05:46 PM
Hmmm - just tried it and yep, that's it !
Bizarre. Should really have a switch on the pump
Thinking cap on for an attractive solution.
Thanks for the quick replies.
Donated in 2018
Old 03-19-2018, 08:23 PM
rgmwa rgmwa is offline
Check Modifications thread for various pump switch solutions.
rgmwa
120346
Old 03-20-2018, 06:18 AM
Thanks, will look. Airplane 1 is nearly done, Airplane 2 is waiting avionics so is easier to modify..
Donated in 2018
Old 03-20-2018, 07:19 AM
maniago's Avatar
maniago maniago is offline
Default Where?
I've been thinking I need fans for my avionics. Just curious, can you guys expound on where these fans are and their configuration please? Imitation you know. Thanks!
Mani
MustangII (FoldingWing) "FirewallFwd&sundries": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
Old 03-20-2018, 08:32 AM
There is a very specific reason the fuel pump is not on a switch.
I strongly suggest you fully understand that before adding one.
Scott McDaniels
Hubbard, Oregon
Old 03-20-2018, 11:15 AM
^^^^ Hint... it has to do with safety.
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-20-2018, 12:00 PM
Mani, the avionics bay on the RV-12 is completely enclosed. The bottom is not open like many other aircraft. The two fans are mounted on the bottom of the avionics bay. One fan blows in and the other blows out.
Joe Gores
RV-12 Flying
