Old 03-19-2018, 10:24 AM
Nova RV Nova RV is offline
Default Thunderbolt IO390 and Airflow Performance FM-150
As some of you know this combination is an option from Vans/Lycoming on the Thunderbolt. The issue is that the kit stock mixture setup geometry does not work with the FM-150 and you need to fabricate new brackets. To remedy this, AFP has a new bracket kit that keeps the stock throttle and mixture cables and allows a simple installation. Just spoke with Don and he expects them to be available mid April / after Sun N Fun.
http://airflowperformance.com/index....e-bracket-kit/
One more point is that a couple of the kit fuel lines need to be changed as well when you use the FM-150. I know that Aircraft Specialty and TS Flightlines have the proper length upgraded lines and full FWF fuel line kits if you want nice fire sleeved replacement lines.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Last edited by Nova RV : 03-20-2018 at 02:24 PM. Reason: Added note about the fuel lines
Old 03-19-2018, 06:25 PM
Tom023 Tom023 is offline
Thanks for the timely post! I just spoke with Don as my engine in coming out of the box in two weeks and confirmed availablility for next month.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed. Avionics and engine installed.
Down to last 90%.
2017 Donation
Old 03-22-2018, 06:08 PM
Aircraft Specialty Aircraft Specialty is offline
Chris helped us develop the FWF package for the Thunderbolt engine with the FM150 fuel servo as well as the single and dual PMAG setup for the RV-14.
He is correct that the stock lines will not all work with this fuel servo, and the stock manifold pressure line will also not work with the PMAG setup.
We offer complete firewall forward kits for the -14/-14A in a variety of mag and servo combinations. (As well as a list of firewall forward component deletions if you utilize our kit) As Chris said, we firesleeve ALL fuel and oil lines in our package.
http://aircraftspecialty.com/rvproducts.html
If you already have the stock Van's firewall forward hoses and just need the replacement lines to work with your FM150 servo, or PMAGs, Tom and I can absolutely help with the firewall forward hose differences also.
Happy Building
Steve
Aircraft Specialty is Your Source for Custom CNC parts, CNC cut instrument panels and labeling, Teflon fuel/oil hoses, Headsets, and many other items for Experimental Aircraft.
aircraftspecialty@gmail.com
www.aircraftspecialty.com
Old 03-23-2018, 07:47 AM
FlyingFox44 FlyingFox44 is offline
Default Part numbers to omit from the FWF Kit
What are the part numbers to omit from the FWF Kit, if one orders the FM-150 Kit?
Alvin Fox
Old 03-23-2018, 07:30 PM
Alvin,
We keep an updated list on this page.
http://aircraftspecialty.com/RV-14%2...d%20Hoses.html
It is broken down by 14/14A.
For anyone who is wanting to utilize the stock hoses from Vans and just needs the FM150 fuel servo hose, the part that our hose replaces is the FF00015.
Hope that helps.
Happy building,
Steve
Old 03-28-2018, 07:24 PM
Default FF00015 Hose
Steve,
Thanks, for the follow up. I got the hose as part of my kit from you.
Alvin
Alvin Fox
