Old 03-18-2018, 09:02 AM
Default Open holes in RV-12 side skin attach
Somewhere around page 7 or 8 of the RV-12iS instructions of Section 23, when you get to actually rivet on the side skins, it refers to Figure one and the line of rivets on the bottom row of the side skin which are to be kept open, which makes perfect sense, of course.
It refers to page 10 and the figure there which has the specific callouts for rivets but many of the holes do not have rivets called out.
Can I properly presume that these holes are also to be left open?
Bob Collins
St. Paul, MN.
Almost ready to start the RV-12iS finishing kit. 480 hours in.
Builder log
Old 03-18-2018, 10:56 AM
rv9builder rv9builder is offline
Most of them are left open, but not all. See post 16 of this thread:
http://www.vansairforce.com/communit...d.php?t=158293
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 03-19-2018, 07:43 AM
Yikes. A lot of thread drift in that one, but good info on that line of rivets. I'll go ahead and zip those up. But, there are two holes, in particular, that have no rivet call out that were my concern. Just two holes in the bottom of the widest part of the doubler. Those are the two that concern me. They seem so random.
Bob Collins
St. Paul, MN.
Builder log
Old 03-19-2018, 07:49 AM
Bob Collins
St. Paul, MN.
Builder log
Old 03-19-2018, 09:25 AM
To answer your (more specific) question..... Yes, all of the holes not assigned a rivet size (other than the ones pointed out in rv9builders link) are intended to be left open. The two you specifically mentioned in a more recent post will be used in Section 38 (finish kit) to attach a gear leg intersection fairing.
Scott McDaniels
Hubbard, Oregon
Old 03-19-2018, 04:00 PM
rolick22's Avatar
rolick22 rolick22 is offline
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished (need to add the panel cut out)
Wings finished (need to add the left landing light)
iS Finishing Kit In work
iS Fuselage Finished
1st GEN FUSELAGE SOLD
Serial#12-0864
N864DR Reserved
Old 03-19-2018, 04:51 PM
Curious. What's on the other side of that? Doesn't look like there's a nutplate.
Bob Collins
St. Paul, MN.
Builder log
Old 03-19-2018, 05:24 PM
rolick22's Avatar
David Rohrlick
PPSEL A&P
Serial#12-0864
N864DR Reserved
