Old 03-27-2018, 11:53 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by majuro15 View Post
With the new display and ECU, do you anticipate having the same controls (ie Mixture knob, ECU selector switch, LOP switch) input? I'm planning my panel and would like to plan ahead.
Tim,
Like on the new CPI2, we'd try to eliminate all external select switches and the mixture knob, having these functions controlled at the display.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 421 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 04-03-2018, 05:08 PM
rv6ejguy's Avatar
We've done a lot more investigation into displays now, trying to listen to the feedback from people to keep it small. We're evaluating displays which will have a mounting footprint of approx. 3.25 inches wide and about 3.5 inch high (rectangular). This is about as small as practical for the functions to be properly usable.
Old 04-03-2018, 08:52 PM
charosenz charosenz is offline
Ross,
I suspect your done our about to be done with upgrades on the list....but...
I would like to see an output to trigger a warning light when preset limits are violated.
I.E. out of range volts, our out of range temps, or out of range AFR....
May be even a way to hold one of the existing buttons down for a LONG press to display error details.......or flash an error code momentarily for that particular out of range issue.....
Charlie Rosenzweig
Old 04-04-2018, 06:39 AM
rv6ejguy's Avatar
Originally Posted by charosenz View Post
Ross,
Charlie Rosenzweig
There has been a check engine light output available for many years on the EM-5 which flashes when any out of range condition happens- low voltage, high or low, temps, MAP. There has also been AFR lean warning and auto richen for many years if you have a wideband hooked up to pin 24 and the window enabled.
Old 04-16-2018, 03:51 PM
rv6ejguy's Avatar
Some basic decisions have been made on CPU and display hardware for the EM-6 after working with an evaluation board version of the CPU for the last couple weeks. This CPU choice will involve learning its ins and outs but will ultimately speed development of other aspects of the ECU and its new features.
We have a reasonably defined development path now to follow on the new design, so can finally start ordering some of the bits mid week to begin work.
Excited to have gotten many of the big decisions out of the way after evaluating the pros and cons of several choices. We didn't choose the easiest path but feel this is the best path to allow future growth of the product.
Old 06-05-2018, 05:47 PM
rv6ejguy's Avatar
Barry got a new eval board last week for the exact CPU we plan to use which has breakouts for all the pins- really nice. He's been studying the architecture and playing with it a bit when he needs a break from the CPI2.
He's itching to get at this full time as it's new and interesting. I have to keep him on the CPI2 for a bit longer though and get it completed before he gets unleashed to start writing code for the new features using this micro.
Old 06-14-2018, 07:31 PM
rv6ejguy's Avatar
Default Display
We're getting a few questions about programmer size to allow for from people planning their panels and using an EM-6 down the road.
While we haven't decided all the details on the display layout yet, we have picked the basic display now. The original size we wanted was simply not available in quantities of under 1000.
All I can say at this point is to plan for a square footprint of 3.5 X 3.5 inches which is about the same size as the present programmer behind the round cutout.
It may be closer to 3 inches tall if we decide not to use any external keys independent of the display but the width should be under or at 3.5.
