Old 02-26-2018, 09:18 PM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Default Here are mine
Toward the bottomhttps://www.dropbox.com/sh/xoc7sj8xh...BGJtl5Ya?dl=0#
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 02-27-2018, 09:59 AM
toc pilot toc pilot is offline
Have a look at my FB page photo section. I am running dual D1000 Skyview and you can see how/where I mounted all my equipment.
https://www.facebook.com/pg/Bill-Hem...=page_internal
Bill Hempel
RV-7: N17HB AEIO-390, Hartzell Composite C/S prop, Dual Skyview D1000. First Flight: Oct 2017
Old 02-27-2018, 11:55 AM
Iluke Iluke is offline
Originally Posted by wirejock View Post
Ivan, Thanks.
I planned to do the same. What goes in the hole in the subpanel on the right?
That's for the map box. Since my budget will only support a single Dynon screen I figured I'd add the map box to have a little storage room. I made it removable so it will be another way to access the area without crawling under.
Ivan Luke
Hope Valley, RI
RV-7 SB
In the finish kit phase
2018 dues paid
Old 03-26-2018, 11:49 AM
Ethanol1 Ethanol1 is offline
Default Dynon Install
Ivan,
Did you move forward with your layout/plan? I am working on layout out the dynon equipment as well.
Mike
Originally Posted by Iluke View Post
larry,
I'm at a similar point an here's what I'm doing. You might find it useful. I'm planning to buy all Dynon stuff so I got the unit dimensions from their website and made up cardboard replicas so I could play around with positions. Turns out that I will be able to fit everything on the aft face of that panel just forward of the instrument panel. What this means (I think) is that I can reasonably expect to be able to install it all after riveting on the forward top skin, but just removing the instrument panel for access.
I'll try posting pictures.
r
Ivan
Mike York
President EAA Ch 25
Old 03-26-2018, 12:52 PM
Default Finalized my sub-panel layout
Mike
I played around with it this weekend and I think I have finalized where I will mount everything on the subpanel. It all appears to fit easily.
I'll try posting an updated picture, but it doesn't always work for me.
Anyway, I have the EMS over toward the right to facilitate leading all the sensor leads forward through the firewall penetration on the right. I've also installed my fuse block on a hinged panel and a central grounding buss in the center.
Again, my plan is to go ahead and rivet the forward top skin and install the windshield all before buying the Dynon equipment. I believe this arrangement will allow me to install everything
Any suggestions would be appreciated.
Ivan Luke
Hope Valley, RI
RV-7 SB
2018 dues paid
Old 03-26-2018, 12:53 PM
I cannot for the life of me seem to be able to master this image posting thing.
Ivan Luke
Hope Valley, RI
RV-7 SB
2018 dues paid
Old 03-26-2018, 03:21 PM
Raymo's Avatar
Raymo Raymo is offline
Ivan, Thanks.
Larry,
If you plan to install an IFR navigator (e.g. Garmin/Avidyne), you'll want to keep a section in the middle of the sub-panel open. Most of those boxes are 9+ inches long and will need to protrude through the sub-panel.
I did not plan for one in my photo but now wish I had. Re-arranging everything later is a PITA, as I am finding with a GNS-480 installation in a friend's completed -7.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 03-26-2018, 05:09 PM
That's the pass-through for the map box.
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2019
Old 03-26-2018, 05:13 PM
wirejock's Avatar
wirejock wirejock is offline
Default FOR box
Originally Posted by Raymo View Post
Larry,
I did not plan for one in my photo but now wish I had. Re-arranging everything later is a PITA, as I am finding with a GNS-480 installation in a friends completed -7.
Yes. I looked up the dimensions. Those boxes are huge!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-27-2018, 10:03 AM
sglynn's Avatar
sglynn sglynn is offline
Default Panel with HDX
I'm doing my panel now with 1 HDX, 1 Garmin 430, and the Dynon D6 for backup. You can see photos on mykitlog.com/sglynn. I had to make access holes in the sub-panel to accommodate the depth of the Garmin and D6.
www.mykitlog.com/sglynn
Steve Lynn
RV-7A
100% Complete
Airworthiness Certification Complete
First Flight in January 2018
Anacortes, WA
