Old 02-19-2018, 08:32 PM
wirejock's Avatar
wirejock wirejock is offline
Default Looking for web pages and photos of panel & cabin forward
I'm building the cabin forward and trying to plan the panel. Two Skyview HDX.
Also trying to plan the substructure for the panel to accommodate electronics.
I've looked through the "Panel" thread but so many photos have expired.
Tried searching and again photos are gone.
I would love to see builder web pages showing photos cabin forward and panels with Skyview HDX. Slider preferred as the structure is a little different.
Nothing against tippers but that's not what I'm building.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-20-2018, 09:00 AM
sahrens's Avatar
sahrens sahrens is offline
Hey Larry,
I can't help you with the slider substructure and fitting the HDX screens, I built a tip-up. However, there is a lot of Dynon sub-components that need a home.
Here is a link to my build.
http://www.mykitlog.com/users/catego...&category=9948
You may find something useful for locating your sub-components. I built an avionics shelf forward of the sub-panel to mount the remote VHF, transponder and ADSB unit.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 02-20-2018, 03:25 PM
n4322b n4322b is offline
I'm a slider but using Garmin G3x touch rather than skyview.
I am managing to mount the various boxes on F7105 including the remote audio panel, engine monitor iterface, voltage control and network interface box together with a grounding bus bar.
That allows for F7105A to be cut out allowing the GTN650 to project forward and a VPX unit sitting below and hinged for access, once the control cables are moved.
That way I can remove one of the screens to get at the connections if needed rather than trying to get under the panel with my large bulk.
Cheers
Ian
Old 02-20-2018, 03:41 PM
Raymo's Avatar
Raymo Raymo is offline
A pic of my slider sub-panel. The hole left of the EMS module goes fwd through the firewall. The hold left of the transponder goes fwd and down between the pilot/copilot for things like AP, trim, flaps, lights, etc. I also have some circuit breakers on the panel for things I want direct control or visibility over.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 02-20-2018, 06:11 PM
bhester's Avatar
bhester bhester is offline
Thumbs up My site might give help
Mines Garmin also but might give you some ideas. Look over the last few years.
Google has stopped finding my site but if you search Bobby Hester RV in bing it will pop right up. Link in my signature. :-)
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2018 VAF donator - alot better than any magazine subscription
Old 02-22-2018, 02:03 PM
wjb's Avatar
wjb wjb is online now
Hi Larry ... here's how my bird is coming together. I elected to build a avionics tray that mounts to the bottom of the ribs from the firewall to the subpanel. It's secured by piano hinges; the pins come out the front side of the subpanel and it simply drops down and can be removed for maintenance I'm going Garmin, so this panel holds the remote comm radio, transponder, EIS box, battery backup and CO detector. All wiring from the aft comes through four connectors in the tray near the firewall:
Here's what it looks like installed in the plane:
The subpanel is relatively uncrowded and primarily used for power distribution. I moved the panel ribs inboard to accommodate the G3X display width. This area is left open as well to be the home of a possible future IFR navigator or other panel mounted box.
All the wiring from the rest of the plane comes in via the tunnel in the cabin.
Here's an early photo of the panel blank in place (cut by UpNorth Aviation ... did a fantastic job!) This will be the home of two G3X panels, ADAHRS, AP control, compass (left side) and Alt and ASI 2 1/4 steamies (top center). The compass hole was placed to enable upsizing to 3 1/8" to accept a standalone EFI (like a G5, etc). Requisite switches and knobs go along the bottom. Note, this panel was fabbed with a 1" extension downwards; the Garmin HW and switches don't really fit on a stock Vans' panel.
All the other electronics boxes are elsewhere in the plane (wings, tailcone, etc). Everything seems to fit well and cleanly ... just like a tipper should! ;-)
This just in ... panel photo update!
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 02-22-2018, 05:59 PM
wirejock's Avatar
Default Idea
That's cool. Not a slider but easy to modify to a slider.
Thanks Bill.
Larry Larson
Estes Park, CO
Disclaimer
Old 02-26-2018, 03:04 PM
Iluke Iluke is offline
larry,
I'm at a similar point an here's what I'm doing. You might find it useful. I'm planning to buy all Dynon stuff so I got the unit dimensions from their website and made up cardboard replicas so I could play around with positions. Turns out that I will be able to fit everything on the aft face of that panel just forward of the instrument panel. What this means (I think) is that I can reasonably expect to be able to install it all after riveting on the forward top skin, but just removing the instrument panel for access.
I'll try posting pictures.
r
Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
In the finish kit phase
2018 dues paid
Old 02-26-2018, 04:31 PM
pjoshyjosh pjoshyjosh is offline
Was at the PNW Aviation Conf yesterday - saw the Dynon Quick Panel display. Have you looked at those? Wow.. very nice. And a dual Skyview panel for an RV7/9 with auto pilot, ADAHRS, COM WAAS GPS, Mode S ADSB IN/OUT Intercom, AOA, 406 ELT, switches/ignition WIFI... all for $19.995 VFR!! saves hours and hours of your time doing wiring and fit up..
http://dynonavionics.com/quick-panels.php
Joshua Muri
N8306R - PA28-140 Purchased 05/2013
N72NJ - RV9A Purchased 10/2017
No N# - RV9/A Kit in progress
Empennage complete. Wing Kit on hand
Old 02-26-2018, 05:35 PM
wirejock's Avatar
Default Cardboard mock up
Ivan, Thanks.
I planned to do the same. What goes in the hole in the subpanel on the right?
Larry Larson
Estes Park, CO
Disclaimer
