Old 02-16-2018, 08:16 AM
TomVal TomVal is offline
Since the stabilizer has to be pulled, if you haven't already done so, might as well complete SB 16-08-01 - Stabilizer Bearing Inspection.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 02-16-2018, 08:56 AM
Default Answers to some of the questions.....
The first discovered instance of cracks was by maintainers of an S-LSA operated by a flight school.
Follow-on investigation found cracks in two of Van's Aircraft's demonstrator RV-12's.
The stabilator must be removed from the airplane and the hinge brackets removed from the stabilator to gain visual access to the area potential to crack (the fwd web of the box spar under the hinge brackets) .
The option was given to delay the installation of the updated parts if no cracks are discovered, to allow owners some flexibility if they can't do the parts installation immediately because of lack of skills (weren't the aircraft's builder), haven't yet obtained the needed parts, etc.
In most cases, it would make sense to just install the new parts while the stabilator is removed for the inspection.
It may be difficult to detect cracks depending on the level of crack development (how big they are) and surface condition (primer or paint coatings, etc.). This is another reason it might make sense to just install the parts regardless of what the inspection results are.
I don't know how the cost of parts is being handled. You will have to ask about that when ordering the kit.
There is a variability in the size of cracks that have been discovered so far.
The red prototype (N412RV) with well north of 2000 flying hrs had very small cracks that were at first difficult to detect. The photos in the S.B. are from that aircraft. Another aircraft with only 1/3rd as many hrs had larger cracks.
It is only speculation, but it is thought that an RV-12 that has sat outside in wind a lot with unrestrained controls (I.E., stabilator banging against the up and down stops because of wind movement) could be more susceptible to cracks.
BTW
An evaluation of the problem after initial report, do an FEA model analysis, design of a modification, production of prototype parts, beta installation of the new parts on two different stabilators and writing of the install instructions and SB document and publishing it, were all done in less than 3 weeks.
Scott McDaniels
Hubbard, Oregon
Old 02-16-2018, 11:00 AM
JwWright57 JwWright57 is offline
Talking
for once procrastination paid off, I'm at the point in my build where this is not a big deal. Also, the hinge brackets did seem a little light, so i'm glad to see they are being beefed up!
Jeff Wright, Charlotte NC
Rv-12 started! Tail 99% done
Wings 50% complete..............
Dues paid 2018
Old 02-16-2018, 11:01 AM
Kudos to Vans for getting this out so quick
Dues paid 2018
Old 02-16-2018, 11:16 AM
Jshepherd Jshepherd is offline
Parts are on the web store $20 plus shipping
Old 02-16-2018, 11:50 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
I kind of wonder if “over-tighting” of control cables might have something to do with this problem....just my trouble shooting mind @ work!
When adjusting and stretching stab cables; I tighten till cable slap stopped which was not as tight as gauge pressure was suppose to be... My concern being the fiber rollers the cables ran over.
Scott....you can jump in here to slap my hand anytime��
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 02-16-2018, 11:59 AM
Phantom30's Avatar
Ditto on that....going to replace bearings and install Stab fix parts all at one time to satisfy annual tail end inspection...
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 02-16-2018, 12:04 PM
Not intended as a hand slap, but I don't think that has anything to do with it.
The load cycle that will cause the most flex in the structure and have an influence on causing the fatigue cracks to occur is the load induced when the stabilator bumps the up or down travel stop.
BTW, the fiber pulleys used are standard aircraft components.... same as used in Cessna, etc.
The cable tensions specified for the RV-12 are very similar to what is used in many other aircraft that use the same pulleys.
Scott McDaniels
Hubbard, Oregon
Old 02-16-2018, 12:51 PM
TLKRV12 TLKRV12 is offline
Default cost of parts for SB 18-02-02
Cost of the parts for SB 18-02-02 $20 USD + shipping
Old 02-16-2018, 09:20 PM
epaslick's Avatar
epaslick epaslick is offline
I'm right there with you. My stabilator is build but not installed on the tailcone. Counting my blessings.
Eric Paslick
EAA Chapter 732
Siloam Springs, AR
RV-12 #120991
Empennage: Started
N62EP Reserved
2018 Donation Made
