POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
04-05-2018, 04:15 PM
My take would be that by scuffing the SS washers and alum brackets and glueing them together the SS at the interface would stay in the active state. Especially if the assembly is primed. It looks like the aluminum would still be slightly sacrificial but for a corrosion cell to form there would have to be an electrolyte present.
Anxious to see where this thread goes...
Tony
RV-12 #202 -- Flying
04-05-2018, 05:19 PM
Tony, you live by the ocean, so salt air with lots of rain in the PNW would be a consideration...
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 320
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
04-05-2018, 09:12 PM
Rain?
What rain?
Tony
04-08-2018, 06:18 PM
Seems like steel and aluminum are in contact at many points in an aircraft. I’ve never heard of it being a problem. Has anyone else?
04-09-2018, 04:14 AM
Cracks
All of the posts and pictures are very helpful. I have not started mine yet. I am wondering how many owners have actually found cracks after doing the inspection?
Thanks.
04-16-2018, 11:22 AM
Removing rivet stems
Originally Posted by JwWright57
I hear you Tony! I had to re-rivet one of the anti-servo hinges and ended up with the rivet tails inside the stabilitor. I cleared them out with a magnet on a long stick and a LOT of fishing around. It was a real PIA.
Has anyone found an easy way to remove the rivet stems after drilling out the rivets for the service bulletin? Amazon.com has several magnetic pickup tools that look like they might be helpful. Has anyone tried one?
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
04-16-2018, 12:52 PM
while one of us rotated the HS around the other caught the moving remnants... took 5 minutes...not a big deal
B2RV12
04-17-2018, 07:25 AM
I installed the stabilator fiberglass tips at the same time. With the end ribs removed I tipped the H.S. on to the leading edge so the rivets went to the front and then up on end and out the rivets fell out.
04-18-2018, 10:41 AM
Thanks, Ben and Jim. I appreciate your suggestions!
RV-12iS Fuselage
RV-9A Project: Sold
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
