Old 02-15-2018, 03:42 PM
DeltaRomeo's Avatar
Your host.
Exclamation SB 18-02-02 Potential cracking in the horizontal stabilator front spar
Issued today:
RV-12. Before further flight.
http://www.vansaircraft.com/pdf/sb18-02-02.pdf
"Inspect stabilator front spar for cracks. If cracks are not present the aircraft may be returned to service until the next 100 hour or annual inspection, when this service bulletin should be performed before further flight. If cracks are found, complete this SB immediately. Kits under construction should perform this SB prior to stabilator attachment or first flight."
v/r,
dr
doug reeves.
VAFDR
N617AR. RV-6. First Flight: Sept 2002.
Old 02-15-2018, 04:01 PM
moosepileit moosepileit is offline
Default RV-12
Model RV-12
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 02-15-2018, 07:21 PM
MrSparkle MrSparkle is offline
Default Inspection for cracks
I assume that the only way to inspect the stabilator's front spar for cracks is to remove the stabilator and the hinge brackets. Agree/disagree?
Ian Heritch
RV-12 N417E
Old 02-15-2018, 08:21 PM
alexe alexe is offline
Agree. At that point you might as well do the fix rather than waiting to do it at the next conditional inspection. This is not going to be fun!
Alex
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2018
Old 02-15-2018, 08:26 PM
E. D. Eliot E. D. Eliot is offline
Default Want to comply!!
I do appreciate this SB and all of the work that the technical staff at Van's must have put into it. Would have liked to order tonight but can't because I'm not sure which new parts need to be ordered. I'll call tomorrow along with many of you.
Recommendation to Van's --- please add a short note that lists the parts need in order to comply. If Van's did that this time then I apologize profusely.
Thanks again for the SB.
Building finally
Old 02-15-2018, 08:28 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Last page of the SB:
"PART NUMBER
Purchase from Van’s Aircraft: SB 18-02-02"
RV-8 SBs had similar wording, and all the parts necessary for the SB modification were included.
Looks like you will still have to call, as "SB 18-02-02" is not yet listed in their "Service Bulletin Parts Kits".
Carl N.
Arlington, WA (KAWO)
RV-8, 340 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 02-15-2018, 10:08 PM
rgmwa rgmwa is offline
Ian Heritch
RV-12 N417E
That's if you can actually see any cracks. They would be very easy to miss judging by the photos in the SB. I wonder what prompted Vans to look there, although I guess it's an obvious potential trouble spot when you think about it. This won't be a fun job, but if you have to pull everything apart to check you might as well bite the bullet and do the fix at the same time.
rgmwa
120346
Old 02-15-2018, 10:33 PM
Harvey rv12 Harvey rv12 is offline
Vans SB’s usually have a “synopsis” detailing what prompted the bulletin.
This SB doesn’t say much. Would be interesting to learn how this was discovered.
Tom O.
RV-12, bought flying
Hoskins Field, 44T
Olympia WA
the bitterness of poor quality
lingers long after the cheap
price is forgotten.
Old 02-16-2018, 06:21 AM
skydiverlv skydiverlv is offline
I like the 6hr labor estimate. That indicates how old and slow I am.
Larry Vandegrift
ULPower 260is, dual ECUs, dual 30 amp alternators
Old 02-16-2018, 07:25 AM
I wonder if Van's will supply parts free-of-charge for this SB like they did for fuel tank and landing gear?
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 366
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
