Old 01-31-2018, 08:19 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Default Navworx ADs600 worth anything?
A friend of mine gave me his NIB 600 EXP, Transmon cable and antenna to try to sell. I have not been following the Navworx debacle and have no idea weather this can still be used with an approved GPS source, or whether it is just a pile of junk. Can anyone shed some light on this?
Bill Peyton
RV-10 - 780 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 01-31-2018, 08:29 AM
DennisRhodes DennisRhodes is offline
If you find a buyer , let me know , maybe he needs two of them.
The certified B models have the option of using an external position source. ( still of value) . The EXP model has been OKd for using as an ADSB IN only by defeating the transmit. Otherwise makes a good boat anchor.
As for the antenna and cable guess it might have some value. I believe the Freeflight uses the same antenna.
DRRhodes
2018 VAF dues paid
RV9 N908DR
Old 01-31-2018, 01:00 PM
Vic LaRocca Vic LaRocca is offline
Default 600 exp
Bill, pls check your private messages. Vic
Old 01-31-2018, 01:16 PM
schaplerrh schaplerrh is offline
Too light for a boat anchor. Maybe target practice?
Old 01-31-2018, 01:31 PM
dtw_rv6 dtw_rv6 is offline
Set it on Bill Moffitt’s doorstep on Halloween, light it on fire and wring the doorbell lol
Old 01-31-2018, 06:03 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
I agree
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2018 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 01-31-2018, 08:46 PM
ssokol ssokol is offline
Default Bench testing
I could use one for bench testing FlightBox systems. PM me if you have one taking up space / collecting dust.
Steve Sokol
EAA Chapter 612
Liberty, MO
RV-6A N101PR
2018 =VAF= Donation Paid
Open Flight Solutions - Maker Of FlightBox ADS-B
(VAF Supporter / Advertiser)
Old 02-01-2018, 07:18 AM
I thought the issue with the exp boxes was and approved GPS source, and I also thought that an AMOC had be approved to allow the 430/530/650 boxes for the source.
Bill Peyton
RV-10 - 780 Hrs
WA0SYV
Old 02-01-2018, 07:57 AM
Except the EXP unit has no way of getting an external approved 4XX, 5XX and etc GPS signal into that model. With the other NW units ( Pn XXXXX /?? , certified , B model ) they evidently have a input for external GPS source and therefore allow that " approved GPS position source" signal for continued service.
DRRhodes
2018 VAF dues paid
RV9 N908DR
Old 02-01-2018, 10:31 AM
rleffler's Avatar
rleffler rleffler is offline
There are actually five AMOCs now. The two most recent cover Avidyne as a GPS source and the other is for the EXP. However, the EXP AMOC requires disabling the internal GPS and using it as a ADSB receiver (no out). While not ideal, it does provide a transition period to leave the unit installed.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
