Old 01-29-2018, 11:12 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is online now
Default Any VP-X Pro installs in a 14/A so far?
I will be installing a VP-X Pro in my RV14A and I'm well into the prep planning for it and the panel equipment.
The panel will have (left to right) a G5X, 10" GDU 465, center stack (top to bottom) GMC 307, GTN 650, GNC 255A (future), and GMA 245, plus right of stack a future G3X 7" portrait GDU 470. May be cutting back even more on initially installed panel equipment depending on taxes, etc.
But here's the 'I wanna' full layout.
QUESTION IS >> Where does the VP-X pro fit best in the space available behind the panel, where do I begin thinking about locating it?
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
!! I SURVIVED RIPON ARRIVAL - KOSH 7/21/2018 !!
Last edited by jeffw@sc47 : 02-01-2018 at 12:52 PM. Reason: Revised GDU 370 to GDU 470 Touch fix
Old 01-29-2018, 03:34 PM
Walt's Avatar
Walt Walt is online now
Just a thought, I always think redundancy/failure plan. If you have 2 10" screens they are 100% interchangable, if the PFD goes TU somewhere.. just swap screens and you're on your way.
So I'd prefer to have 2 10" or 2-3 7" units rather than one 10" and one 7".
(PS: you can't mix and match 370 screens with 4XX screens)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 01-29-2018, 06:14 PM
Flywade4 Flywade4 is offline
I Install one in my RV14A
RV14
Due pd 2014, 2015, 2016, 2017
Emp 95% done
Wings 95'% done
Fuselage 90% done )
Firewall forward 95%
Old 01-31-2018, 04:49 PM
iamtheari iamtheari is offline
I am leaning towards the VP-X Sport in my 14. But I am many hours from needing to commit. Iím curious why you chose the Pro over the Sport.
Old 01-31-2018, 05:28 PM
Davoakes@att.net Davoakes@att.net is offline
I installed a Sport model in my RV7A not a RV 14 only because it was cheaper than the Pro and I did not need the extra circuits that the Pro provided. I think the Pro model also did some extras that I did not consider of value to me.
I think the sport model is enough for me.
I hope that this testimony helped you some.
Daveoakes
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 03-06-2018, 11:08 PM
Junk8 Junk8 is offline
Default VPX Pro
I have mostly Dynon screens and I put the VPX on a shelf I made behind the right side screen. Easy access to the Ethernet port and it rides under the Dynon screen.
Old 03-07-2018, 09:42 PM
Tdeman's Avatar
Tdeman Tdeman is offline
The photo shows a GDU 370 on the far side, although he said he was planning on adding a GDU 470 (which, as I understand, is compatible with the GDU 460)
This post brought to you in part by, pour-over coffee, sleep deprivation, and a need for speed.
Opinions expressed in this post do not necessarily represent those of my employer.
Old 03-29-2018, 03:02 PM
Kbolvin Kbolvin is offline
I installed a VPX Pro in my 14 behind the subpanel. I made a little shelf and installed it behind the radio opening in the sub panel. That allowed me to bring the fuselage harness up the center channel and right to the VPX for the appropriate wires.
