Old 01-19-2018, 11:31 AM
givo givo is offline
Originally Posted by N941WR View Post
È il carburatore. Io sono curioso di sapere quali accensione avete e sono essi a tempo correttamente?
(In English: That is the Carburetor. I am curious about what ignition you have and are they timed correctly?)
Sorry the ignition is Unison Industries Slick Magneto , the engine has 50 hours so I suppose they are correctly timed
Old 01-19-2018, 11:54 AM
Originally Posted by Mel View Post
Are you sure that the "eyebrows" are installed in the upper cowling over the inlets? If these are missing, it will cause overheating at high AOA.
This is new to me …I ‘m not sure to know what "eyebrows" are ? is some device that is not standard in the kit ? some kind of conveyors that you install inside in inlets of upper cowling
Old 01-19-2018, 12:09 PM
Mel's Avatar
Mel Mel is offline
It IS standard in the kit. It consists of fiberglass pieces glassed in to smooth the inlet airflow above the air inlets.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 01-19-2018, 12:51 PM
Hi Ray , I have the gear fairings installed , I wonder how they can influence engine cooling ….anyway I have standard Slick Magneto , I will check baffling for leaks , thanks for the info about temperature Giulio
I will check thanks
Old 01-19-2018, 01:52 PM
N941WR's Avatar
N941WR N941WR is offline
Mel accennato i pezzi in fibra di vetro che vanno all'interno della mucca superiore che le transizioni (liscia) il flusso d'aria dall'ingresso al camino.
Ci sono anche i deflettori di alluminio che ottenere rivettati per i deflettori e alzarsi davanti a cilindri #1 e #2. Lo scopo di questi è quello di spingere verso l'alto l'aria sopra i due cilindri anteriori e costringendolo alla parte posteriore due.
Che vi aiuterà a bilanciare tutte le temperature del cilindro.
Vorrei anche avere il tuo tempismo magneto controllato, solo per essere positivo che è corretto per il tuo motore. Se è avanzato, dire 28 gradi anziché 25 gradi, si vedrà di CHT alta durante le impostazioni ad alta potenza.
In English:
Mel mentioned the fiberglass pieces that go on the inside of the top cow that transitions (smooths) the airflow from the inlet to the cowl.
There are also aluminum deflectors that get riveted to the baffles and stand up in front of cylinders #1 and #2. The purpose of these is to push the air up over the front two cylinders and forcing it to the back two.
That will help balance all the cylinder temperatures.
I would also have your magneto timing checked, just to be positive it is correct for your engine. If it is advanced, say 28 degrees rather than 25 degrees, you will see high CHT’s during high power settings.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-23-2018, 07:43 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default PICTURES!
Givo:
Pictures of the inlet area please. We can see if the eyebrows are installed.
Thanks!
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 01-23-2018, 07:51 PM
F1Boss's Avatar
Default Local contact
I have a customer in Balzano who might be able to help you. Elmar Marinoni lives there, and flies a Rocket. You could ask him to have a look?
Strikler & Marinoni OHG - I do not have a telephone number. Sorry!
Good luck!
Best,
Budd Davisson, 1997
Old 01-23-2018, 10:27 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Recheck your engine specifications. I think that 400 degrees is acceptable.
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual experimental touch screens with autopilot, IFR GPS)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2019 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 01-24-2018, 06:14 AM
caryr's Avatar
caryr caryr is offline
Quite a few of us have been there.
Rejet the carb to flow more fuel on take off.
You will be amazed how much this helps.
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
